Old 04-22-2024, 11:48 AM   #1
Saffir3
BBL-BEE
Saffir3's Avatar
Drives: Bright Yellow SS 1LE
Is E85 worth it on NA LS3
I know its not worth it in terms of horse power. But is is worth it in terms of cleaning the engine better, more knock resistance, and running cooler. Im going to build an LS3 with a stage 4 cam, 1-7/8" long tubes, a CAI, ported intake manifold, ported throttle body, 25% underdrive pulley and a full 3" exaust with no cats. Would any of the benefits listed make a diffrence? Are there any other benefits that I havent listed, is it worth it? For my goals? Id appreciate all the help.
Nuthin' But Bolt On's: eBay 1-7/8" Long Tube Headers, SLP Blackwing Cold Air Intake, Phastek Race Scoop, 3" Maximizer Exhaust + 3" Muffler Delete In-To 4" Chrome Tips, Taylor "409" 10.4MM Wires.
No Thoughts.......Head Empty
Saffir3 is offline   Reply With Quote
Old 04-22-2024, 03:27 PM   #2
hammdo
'It's an experiment'
hammdo's Avatar
Not really, if boosted sure. While clean burning is true, don’t think it’s worth the effort…
-Don
747 RWHP 794 RWTQ
Old 04-22-2024, 04:49 PM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yeah, from what I've read on here, and the guys I've talked to as well, on a NA'd engine it won't gain you much for the effort and equipment needed to run it. Sure it might be cheaper to buy, and cleaner burning, but you WILL use more of it, and that will offset any money you thought you'd save by not using plain ole 93, or any premium fuel. All my friends running a boosted application use it, with nice gains.
Old 04-22-2024, 05:54 PM   #4
Bluebagger06
Bluebagger06's Avatar
Drives: 2012 camaro ss
Yeah i was told the same , Maybe 6 or 8 HP ,so i didnt think i would do it but now with HP Tuner and i got a line on some injectors and pump i am thinking i going to just do it. Main reason is now by me 93 is $5 a gallon and E85 is $3.07!I also plan to do something later that E85 will help!
GPI Powered
Bluebagger06 is offline   Reply With Quote
Old 04-23-2024, 06:40 AM   #5
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
You have to do the cost benefit analysis for yourself. Anyone running boost can see big benefits by running e85. For those not running boost, my rule of thumb would be if the use of race fuel would ever be required. $3/gal e85 beats the hell out of $10/gal (or more) race fuel.
How you do it is also a big determinant of the return. Do you intend to pay 1k for a DSX kit or can you get by with ZL1 pump (or modify yours with a Deatschwerks replacement) and a Continental fuel composition sensor <$100? Are you doing the work, or are you paying someone? If you can do it yourself, including adding the pin to the ECM connector, then the biggest cost is the tune change.
If you have no need for 105 octane fuel, it's probably not worth the effort unless you believe the zombie apocalypse is coming and you will need to make your own liquor, I mean fuel.
Old 04-23-2024, 08:44 AM   #6
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
When my car was heads/cam I did still run E. I had to upgrade injectors to FIC 660s. I also had the DSX flex fuel kit. My car would get 10.5 city driving pretty conservative and 15.5 highway at 80mph.
No idea what pump gas numbers were but with E it made 513whp and 463wtq. The mods were, CAI, PTB, LTH, Ported manifold, M311 heads, FIC 660 injectors, custom grind cam and the DSX flex fuel sensor.
Old 04-23-2024, 11:53 AM   #7
gm2376
gm2376's Avatar
Drives: 2010 Black 2ss Camaro SS
not at all
Apex VS-5RS Forged Wheels,Dart 388,ECS Supercharger 2200x, E85 Flex Fuel sensor, Dart 388 , B&M Tranny Cooler, Vigilante 4000 Triple Disc TC,Katech Ported Heads, Texas Speed Sheet Metal Intake, ECS Big Blower Cam,ID 1700s, Fore Triple Pumps, E85,ATI Super Dampner, KW V3 Coilovers, Pfadt front and rear sway bars,Pfadt Trailing arms and toe rods,ZL1 Rear Diff, RPM 6l90e level 10 Tranny, SW Long Tubes no cats,Nick Williams Boosted 103mm TB, Dr Phil Tune,Borla Atak...955rwhp/967rwtq
gm2376 is offline   Reply With Quote
Old 04-24-2024, 01:23 PM   #8
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
A bump in compression will help as well.
Orange Krush II
Old 03-19-2026, 03:37 PM   #9
White_widow_SS
2015_white_Wido
Drives: 2015 SS Camaro Chevy
Injector questioning
Currently I have
Headers, air intake, exhaust tuned New era 2015 SS Camaro Ls3
I’m thinking in E 85 to add and was wondering if deatschwerks 65 lb would be good with my car and if they were a reliable brand or get 52 lb lsa Bosch ? I would also be running stock pump for a bit till I eventually get zl1 pump. End goal of to stay with this set up.
White_widow_SS is offline   Reply With Quote
Old 03-19-2026, 03:42 PM   #10
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Originally Posted by White_widow_SS View Post
Currently I have
As we all stated above, unless you're installing a SC, don't waste your time and money! It's not worth it. Do a cam swap instead, you'll gain a lot more that way.
Old 03-19-2026, 05:44 PM   #11
White_widow_SS
2015_white_Wido
That’s cool but na I’m looking for which injectors as stated. And ima leave it as is no seed for that. I’m doing e for the price, cooler engine, and the smell
Old 03-20-2026, 07:32 AM   #12
gtstorey
Bosch injectors can be problematic getting good GM format data. And I don't know what "lsa bosch" injectors even mean. However anything that is truly an LSA injector has a spray pattern that really only works well with the LSA intake. But I don't remember seeing a Bosch injector with that spray pattern.
