Old 04-22-2024, 11:00 PM   #1
RupertPupkin
Drives: 2014 Camaro SS 1Le
What can cause this?
Ran gates green belt, but it keeps shredding on me. That's usually if I do so hard pulls. But on a regular cruise, it's fine. Switched to a regular gates belt since shits getting expensive.
Anywho... help me diagnose this. I think it was doing the same with the gates green belt, but I just never paid attention.
It may seem like....
- the belt is too long, but it's the same series and same length
- pulleys are not aligned, they're aligned. Straight edge and laser confirmed.
- tensioner is not providing enough tension, that bad boy is tight as tight can go.
- SC pulley spins freely, no wobble, checked other pulleys also and they're good.
https://youtube.com/shorts/-w1iUS7IW...Y5Cq0yorp7jjyo
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 04-23-2024, 07:04 AM   #2
cc-rider
Drives: 2010 Camaro SS
That long run of your belt on the bottom off that video looks like it’s a little sloppy and flapping around. Is it slapping against something down there? You may need more tension. These belts stretch more than you’d believe under high rpm and load. Go see some videos of that on YouTube. Kind of amazing how far they can balloon out. My guess is that your belt is contacting something under high rpm/load and stretch and it’s shredding it up.
I put a JRE Supertensioner on mine and it’s a nice piece.
cc-rider is offline   Reply With Quote
Old 04-23-2024, 08:23 AM   #3
fz4k98
Drives: 2013 1ss
Are there any witness marks on the belt showing an impact? Can you tell if it is breaking in a certain pattern like edge toward center or center toward edge? Do you have any close ups of the broken portion of the belt?
fz4k98 is offline   Reply With Quote
Old 04-23-2024, 10:52 AM   #4
RupertPupkin
I figured there's a lot of slop, compared to the other vids I've seen on YouTube. The only thing I can think of is to bottom out the tensioner, and see where that goes.
The belts shred in 2-8 pieces, so no idea.
730whp: 630Trq
Old 04-23-2024, 12:10 PM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I agree with cc on this one. That bottom of the belt is slopping all over the place, and if you look at it you can see that it is also walking side to side a little bit. I'm guessing when you run it up the belt is hitting on the back side of it from the SC to the tensioner pulley, or possibly in another area. One of my friends that had a 2011 vette grandsport had a crank pulley start separating since they were a 2 pc unit, and his belt was walking around side to side like that. But I'm not sure what kind of crank pulley you have on there. Just another thought. I hope you get it resolved.
Old 04-23-2024, 07:30 PM   #6
RupertPupkin
Thanks. I disassembled the tensioner and 1 of the idler pulleys and tinkered with it a little. Lo and behold I was able to get it tighter. Hopefully no more shredded belts.
https://youtube.com/shorts/xYkD3Bxau...kOAA3SgBtX_hBJ
730whp: 630Trq
Old 04-24-2024, 12:48 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Cool. But what is that black pulley in the lower right hand corner of the vid that it only shows half of it! It is still bouncing around quite a bit, and the belt is still moving around a lot, that might be an issue to look at too.
Old 04-24-2024, 12:59 PM   #8
RupertPupkin
That's the supercharger pulley. Looks wobbly but it isn't.
730whp: 630Trq
Old 04-24-2024, 01:11 PM   #9
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Oh wow!! That thing is wobbling quite a bit, looks like. I've not looked at any of my friends SC setups to see if that is normal or not, but keep an eye on it. The rest of the belt and tensioner look great though. Hope what you did works out. Gotta be frustrating.
Old 04-24-2024, 03:26 PM   #10
RupertPupkin
I think with the camera so close and all the crap that was in the pulle (belt residue/dirt) gave the illusion of the wobble.
730whp: 630Trq
Old 04-26-2024, 09:55 AM   #11
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
Is there room to add another pulley where its moving around to take some deflection out??
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 04-26-2024, 10:17 AM   #12
RupertPupkin
I wouldn't even know and haven't really checked that option yet. I was thinking of it, but that was in the back burner. I think adjusting the tensioner bracket helped tremendously, and possibly resolved my issue.
I did do a WOT til 5500-6000rpms and no issues. That's where the belt will usually break.
730whp: 630Trq
Old 04-26-2024, 11:32 AM   #13
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 2021 Camaro ZL1 1LE A10 (stock)
This may or may not be a little off topic, but I picked up a Gates RPM High Performance serpentine belt since I couldn't find the green HD belt (over the regular belt). I reckon it's supposed to stretch less, not sure. I wonder how daily friendly that RPM belt would be?
> Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily
dreksnot is offline   Reply With Quote
Old 04-26-2024, 03:05 PM   #14
RupertPupkin
I bought an rpm belt also... that snapped not even 5 min into my drive. I know the belt have different belt tension tolerances. The regular belt need 90% tension, the green 65-75% and the rpm in the 50-% tension since they don't have any give. The rpm belts are nice, and very stiff, but damn they're expensive. I'm going the cheapest route for now. I snagged 3 regular belts on eBay for 50$
730whp: 630Trq
