Old 05-07-2024, 09:54 PM   #1
jacobcarrasco7
Drives: 2011 CAMARO 2SS
Trouble Starting
I recently changed my starter on my Camaro 2011 SS due to having hot starts. I added header wraps and even a starter wrap and keeps doing the same thing, now i get clicks now, won’t turn on when hot. I got 91 tune, long bbk headers, and twin disc clutch, few others things. I can’t figure out how to fix the issue. I haven’t tried changing the alternator, do you think that could be the issue? or ignition coils, or even coilpacks? I have heard that adding another ground cable could help or just replacing the ground positive cables all together!
jacobcarrasco7 is offline   Reply With Quote
Old 05-07-2024, 11:43 PM   #2
InFiD3ViL
InFiD3ViL's Avatar
So I already have a PowerMaster high torque start and an additional 0 gauge ground from driver side head to frame rail. What solved my hot start issues was 2 things. I added an additional 2 gauge ground in the trunk from the battery to the OE battery ground location. But I also had apparently unknowingly cross threaded that same battery ground location bolt (prior to the hot start issues), which caused the bolt to snap. I drilled it out and bolted it in with a new coated bolt from the under the car. So basically, I had a poor trunk ground. But I am certain that adding that trunk ground helped. Of course, all the hot start issues toasted my nice AGM battery, so I replaced that as well.
If I was giving advice, I would simply do one FAT cable underhood and another one in the trunk direct from the battery to the ground bolt. Of course you will want to check all other underhood and body grounds, if you haven't already. I haven't had a single issue since then (2+ years now).
Good luck! I know how much this sucks. When I was dealing with this getting gas was the most stressful time, as it was never long enough to allow the starter/cables to cool.
Old 05-08-2024, 03:36 AM   #3
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Sounds like you could possibly have a bad solenoid on the starter. I would take the starter off and have it tested at your local parts store.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
crank, engine
