Old 05-10-2024, 09:57 PM   #1
tarik1985
tarik1985's Avatar
Drives: 2010 Camaro SS/RS
Is my car shifting normally after a circle D torque converter install?
Hey everyone,
Just got my car back after having a Circle D torque converter installed and a tune done. Overall, the car feels great so far but I'm wondering if the way it's shifting is a normal result of the torque converter upgrade or if it might be a tuning issue. The shifts are definitely firmer, and I've noticed that when I let off the gas in 5th or 6th gear, the car downshifts pretty hard ( jerks the cars) , This only happens on one gear.
Is this a normal behavior after the torque converter installation, or could something be adjusted in the tune? Any insights would be appreciated!
Driving video:
https://youtu.be/XiMnJITDD5Q?si=I0_LpaWzyBktWXVk
2010 Camaro SS/RS L99.
tarik1985 is offline   Reply With Quote
Old 05-11-2024, 05:58 AM   #2
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I can't tell if it's downshifting when you let off the gas or not. I'm wondering if you mean it's upshifting when you let off the gas or are you talking about the way that it upshifts when you're on the gas. And what stall did you get? The jerks that your getting depends on how much pressure that is set up in the tune. Like the upshifts, the adaptive oncoming pressure presets, and whether or not if your torque reduction is all turned off.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 05-11-2024, 08:36 AM   #3
RupertPupkin
Drives: 2014 Camaro SS 1Le
Is this your 1st time having a trq converter?
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads
FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch
730whp: 630Trq
RupertPupkin is offline   Reply With Quote
Old 05-11-2024, 11:06 AM   #4
tarik1985
tarik1985's Avatar
Yes, it is.
Old 05-11-2024, 11:11 AM   #5
tarik1985
tarik1985's Avatar
Hmmm.. Now I'm second guessing when it does it.. Lol
So if I step on the gas, let's say from 10mph to 65mph, then I move my foot off the gas and let the car slow down on its own without using the brakes.. Somewhere between 50mph to 40mph the car jerks once while auto shifting.
Old 05-11-2024, 12:23 PM   #6
morepowerjoe
It sounds like it's shifting pretty good in the video. They probably just have your pressures raised a little high. If you don't like it shifting that hard you could ask the tuner about maybe lowering you shift pressure down a little.
Old 05-12-2024, 07:43 PM   #7
RupertPupkin
Yes, it is.
It takes time getting used to. When I had it in my old G8GT, it was a different driving experience. The shifts are quicker and crisper up and down.
730whp: 630Trq
Old 05-13-2024, 09:08 AM   #8
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Nothing stuck out to me, seems about like what you'd expect from a modest stall.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 05-15-2024, 07:27 PM   #9
tarik1985
tarik1985's Avatar
Thank you for the response guys. After driving it for a little while I'm getting used to it, and it's way more fun to drive
