![]() Drives: 2011 Camaro 2SS/RS Join Date: Jul 2021
Separate clutch resevoir (master cylinder plug)
For those that did a separate clutch reservoir and didn't buy the $50 kit, what did you choose for plugging the original port on the master?
![]() Drives: 2010 2SS RS Join Date: Apr 2023
Just do it correctly
I am. I have the correct reservoir. The kit isn’t the only “correct” way. It’s just overpriced reservoir, hose, and bracket. I can get those things easy enough. Just deciding best method of plug.
![]() ![]() ![]() ![]() ![]() Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Rubber cap and zip tie.. works just fine. I did however just buy the kit. 40$ to my door. By the time I tried piecing my own, it was a couple of dollars less.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
Use a automatic reservoir.
Orange Krush II
#6 | |
It's $50 now plus shipping. I have zero problem spending money on the car. It's a toy that requires cash. Heck, I just got done putting several thousand in the drive train. No biggie. I just get annoyed when I see something like this where a few basic parts at gathered and the "kit" price feels high. |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
I have the G8 reservoir on one and a Wilwood on the other. Rubber cap on both with no leaks. I think the G8 kit came with the rubber cap and I just pulled one out of parts drawer on the Wilwood.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
#8 |
I picked up a G8 reservoir. And yeah, just noticed it's shipped with a little snap on cap. It seems to be air tight, so can probably use that and be done.
#9 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
That's what I did, never a worry about leaks that way
UPSTATE C5 MEMBER
#10 | |
#11 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
The Metal clamp that came with the kit i could not no matter what I did get it on the Rubber cap. I did use a zip tie and have no issues unless i try to use my power bleeder.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount. |
#12 |
![]() Drives: 2015 Camaro 1le, 2000 Honda CRV Join Date: Mar 2021
I just took off the reservoir and used my little propane torch. I melted it shut and reformed it and now there’s just a plastic nipple there and cost me nothing.
#13 | |
It don’t come easy.
#14 |
Melting it would be the way to go I bet.
