Old 05-18-2024, 01:57 PM   #1
spyderbuddy
oil pressure sending unit
Quite strange with the Oil pressure sending unit very easy to replace, but my gauge was showing ether 0 oil pressure or 70+ oil pressure after engine was warmed up (199-203) Engine no damage, but i never got a check engine Light
or Check Gauges
anybody else get this strange oil pressure reading?
Old 05-21-2024, 06:05 PM   #2
Mouse330
Mouse330's Avatar
Drives: 2011 2SS, 2006 GMC Sierra
Scan for codes you will probably find oil pressure sensor circuit codes like a P0522 or P0523, You can disconnect the oil pressure sensor and test the circuits
With the ignition in RUN, test the Gray wire for 5 volts.
Test the Black wire for ground.
Test the Tan/White wire for less than 4.8 volts.
If the circuits test good replace the oil pressure sensor
Mouse330 is offline   Reply With Quote
Old 05-28-2024, 05:27 AM   #3
2010sgm
2010sgm's Avatar
Drives: 2010 Camaro 1LT
i would say change sensor
David Vianu
2010 Synergy Green 1LT
2010sgm is offline   Reply With Quote
