Old 05-30-2024, 06:38 AM   #1
RoadRunner70
Drives: Chevy Camaro SS 2012 Auto/TR
Red face Burnout procedure for A/T )))
How to properly perform a burnout on a 2011 Camaro SS with automatic transmission?
Do I need to completely turn off the traction control (holding the button for a long time) or switch the Stabilitrack to Competetive mode? Do I need to put the transmission in M ​​(S) mode?
I tried to switch the Stabilitrack to Competetive mode, set A/T to M, the rpm grew to 4000 but nothing happened, the car pulled forward with the brakes applied
and two more related questions
1) What is the purpose of the Competetive mode on the 5th gen?
2) Is there a system for redistributing pressure on the brakes from rear to front and how does it work (or how to turn it on)?
RoadRunner70 is offline   Reply With Quote
Old 05-30-2024, 12:02 PM   #2
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
In 2010 i do : T/C off and holding the button for a long time to Stabilitrack mode.
D or S mode,it does not matter.
Btw.When both TCS and StabiliTrak lights are on, the vehicle is in Competitive Mode.
Competitive Driving Mode allows full engine power while the StabiliTrak system helps maintain directional control of the vehicle by selective brake application. In this mode, TCS is off and Launch Control is available. Adjust your driving style to account for the available engine power.
Old 05-30-2024, 06:51 PM   #3
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM #93
Turn the Nannie’s completely off and let her eat.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter.
‘87 IROC-Z Iroc blue. all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
Old 05-31-2024, 12:10 AM   #4
RoadRunner70
Nothing happens, car moves forward on the brakes, overcoming the force. The brakes are new (front Powerstop, rear Akebono), fluid changed more than 1 quart.
TC completely off, A/T in M mode, gear 1 selected.
Is there a pressure relief system for the rear wheels?
Old 05-31-2024, 02:33 AM   #5
InFiD3ViL
InFiD3ViL's Avatar
Is this Camaro totally stock? I ask because my car was a PITA to do burnouts in before I started modding, especially the tune. So don't worry, this is not the first time I have seen someone with the 6L80e struggling to do burnouts.
Old 05-31-2024, 05:23 AM   #6
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
Yes there are multiple things that are recommended to be turned off in the tune for a good burnout.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 05-31-2024, 05:34 AM   #7
RoadRunner70
Yes full stock . what does it mean PITA
Old 05-31-2024, 07:29 AM   #8
Ashen 6.2
Ashen 6.2's Avatar
Drives: 2014 Camaro Z/SS
PITA = Pain In The Ass
Tuned by Ben @BWTuned, GPI 416 w/GPI S/C Cam, GPI Ported Heads, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump/DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Rossler T400 w/t-brake, Circle D Converter, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Wiles Racing Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP
Ashen 6.2 is offline   Reply With Quote
Old 05-31-2024, 07:39 AM   #9
Blue 13
3P171 USAF Combat Arms
Blue 13's Avatar
Drives: 2013 SS/RS
PITA - Pain In The A$$
I know stock I just did like stated above, hold down the traction control button for 6-8 seconds to turn everything off and it spun the tires. Now I just have to press the gas pedal.
416ci LS3/Vortech V7/Built 6L80
996.6 RWHP 794.9 RWTQ
Blue 13 is offline   Reply With Quote
Old 05-31-2024, 08:32 AM   #10
Aqua Blue RS/SS
Drives: ABM #93
Both of mine when stock had no problems letting them eat with the Nannie’s off. Are you holding the brakes to tight? All you really need to do is hold the brake tight enough to get the weight shifted to the front then once you feel that happen release the brakes slightly and get on the skinny pedal and it should take off.
Old 06-01-2024, 01:45 AM   #11
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
I set the line lock and dumped the clutch… Lotsa smoke…
Old 06-01-2024, 02:41 AM   #12
Danial
Danial's Avatar
Drives: 2013 SS/RS, 2015 Camaro SS/RS Vert
THIS!
"Never cough into a full ashtray."
Danial is offline   Reply With Quote
Old 06-05-2024, 09:10 AM   #13
CorvetteC6
Drives: 2011 Chevy Camaro SS Auto
i can confirm that burnout is not working on SS with AT. I tried several times on all modes .... it's good way to break the brakes ��
CorvetteC6 is offline   Reply With Quote
Old 06-05-2024, 04:48 PM   #14
spyderbuddy
Dude I can do a Full Burnout with a POS V6 come on
