![]() ![]() ![]() ![]() Drives: 1SSRS RY L99 Join Date: Aug 2009
Connector/Pin/Wire layout for under main fuse panel.
I have a little electronic project on the go. I need information on the wiring underneath the main fuse panel under the hood. I was looking at it today and found those 3 10mm bolt heads are for 3 big connector bodies on the underside of the fuse panel so there is no direct access to the wiring to the fuses. I need to tap into the ignition feed the engine ECM which is 5amp fuse #15. I would also like to tap into the horn at fuse #51. If anyone has any wire information or diagrams that would be great!
thanks! |
| GM bulletin on Perceived Paint Mismatch on Door and Quarter Panel Paint Appearance | Tran | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 53 | 07-17-2013 02:16 PM |
| GM bulletin on Perceived Paint Mismatch on Door and Quarter Panel Paint Appearance | Tran | 5th Gen Camaro SS LS LT General Discussions | 114 | 04-16-2012 04:04 PM |
| Detroit News panel wants GM to build Camaro concept | Tran | 5th Gen Camaro SS LS LT General Discussions | 12 | 03-15-2009 05:38 PM |
