GRIM
Drives: 2015 Camaro Z/28 Join Date: May 2010
Alternator
Could use some help. I believe my alternator is on the verge of going out. The alternator is the original (2015). Has always displayed 14 volt output. The other day in route to a VA appointment, and upon arrival, my radar detector that is synchronized to monitor voltage output and battery charge ~ checked dash readings (voltage reading 12-11.8 volts.
Took my Z to a well renowned performance shop and was told all checks were made (computer readings, connections, belt, pulley, sensor etc) being told the alternator is putting out. So, I was informed no need to change alt. So, believing that the alternator is going or gone needs replacing, guy’s… what do you think? Should I just go ahead with what I believe and replace the alternator? Greatly appreciated. Last edited by richard grimsley; 06-01-2024 at 12:28 PM. Reason: Typing error |
![]() ![]() Drives: 2015 Z/28; 1969 Camaro SS Join Date: Nov 2015
Sure. Sounds like all diagnostic was done. I assume you’re not on the original battery?
![]() Drives: '15 Z/28 Join Date: Nov 2021
Aren’t these alternators clutched? So sometimes they are charging and sometimes they are not depending on some parameters. Please correct me if I am wrong.
GRIM
Alternator
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Displaying 14v all of the time is the part that doesn't sound correct but 11.8 is also a little low.
https://www.camaro5.com/forums/showp...28&postcount=7 |
#6 | |
GRIM
#7 |
![]() ![]() ![]() ![]() Drives: 2010 2SS/RS A6 Join Date: May 2019
Has anyone thought about how charging works properly if a second ground cable has been added to the trunk ?
2.cables in parallel,but only 1.current sensor.
