Old 01-25-2010, 08:46 PM   #1
Gr8_syder
Drives: 1996 v6 Camaro
wheel hop
i get really bad wheel hop when i take off and i want to know what to do to fix it. i dont want to break anything because of wheel hop if anyone can help plzz let me know. i have replaced the back shocks, the rear end came from a 1996 z28, my transmission mount has been replaced i;m about to replace the torque arm mount.
Gr8_syder is offline   Reply With Quote
Old 01-25-2010, 10:28 PM   #2
White_Knuckle_Tight
Drives: 2001 Camaro V6
http://mods.firebird*******/
Go there and click on the suspension link. It gives a very thorough explanation of everything...hope this helps
White_Knuckle_Tight is offline   Reply With Quote
Old 01-26-2010, 10:36 PM   #3
Gr8_syder
the Panhard Rods are the ones that go from the frame behind the doors to the rearend right near were the brakes are. and the rear control arms are the ones that mount near the gas tank. and how easy are the adjustable panhard rods to adjust?
Old 02-02-2010, 07:29 PM   #4
Gr8_syder
does this seems like a good price? http://www.summitracing.com/parts/UPI-201520-R/
Old 02-03-2010, 08:15 AM   #5
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
the Lower Control Arms (LCA's) are the ones that mount to the frame and connect to the underside of the axle and keep the axle from moving forward and backward during acceleration. the Panhard bar (PHB) connects from one side of the axle to the frame on the other side of the car and keeps the axle from moving left and right.
check out www.herronperformance.com
Guy's name is Shon, tell him Spike sent you, he'll hook you up!
I piss excellence
and fart awesomeness
Old 02-04-2010, 06:19 PM   #6
KBearZ28
Drives: 98 Camaro Z28
Send a message via AIM to KBearZ28
You can also give Steve Spohn of Spohn Performance a call or drop him a PM.
He is a Camaro owner/enthusiast and a member of the forum. I have Spohn products on my car and I am very happy with the quality and results.
Spohn Performance, Inc.
494 E Lincoln Ave
Myerstown, PA 17067
Tech: 1-888-365-6064 (8:30-4:30 Eastern, M-F)
Web: www.spohn.net
Kevin
John Sauder Buick-Pontiac-Chevy
Ephrata, Pa
717-859-7700
KBearZ28 is offline   Reply With Quote
Old 02-07-2010, 09:20 AM   #7
White_Knuckle_Tight
Huh...that's weird, Summit used to have the Panhard rod/ trailing arm package just a few days ago. For wheel hop, this is what you need
http://www.jegs.com/p/Hotchkis/Hotch...57224/10002/-1
I don't have the trailing arms, but I have that panhard rod, and it is amazing. There was an unmistakable difference in fast curves and cornering. Just as firebirdv6 says, I've heard from alot of people that that package is an amazing upgrade. Since you've already replaced your shocks (hopefully with good ones) then with that Hotchkis upgrade should solve your wheel hop problem. "Should" I don't know for sure
Old 02-08-2010, 07:02 AM   #8
Gr8_syder
i would love to get that one from jegs but i cant spend that much thats y i was lookin at the umi set
Old 02-09-2010, 05:24 PM   #9
Arctic2002ss
Drives: 2002 Camaro SS
My car had BMR lower control arms when I bought it and it has very little wheel hop so I would say to start there.
Craig
2002 Camaro SS - Arctic White
Arctic2002ss is offline   Reply With Quote
Tires loosing pressure joepitt Wheels and Tires Talk Sponsored by The Tire Rack 22 12-11-2010 06:00 PM
Suspension guys out there - lets talk wheel hop Crowley Suspension / Brakes / Chassis 14 10-09-2009 01:06 AM
wheel hop edhaysjr@verizon.net Wheels and Tires Talk Sponsored by The Tire Rack 4 07-11-2009 03:51 PM
What supsension upgrades to combat wheel hop?? ironpeddler Wheels and Tires Talk Sponsored by The Tire Rack 10 06-04-2009 11:13 PM
challenger slow because of wheel hop? What about Camaro? jordan 572 5th Gen Camaro SS LS LT General Discussions 77 02-17-2009 10:23 AM
