Old 06-09-2024, 08:24 AM   #1
Motopsycho
Motopsycho's Avatar
Drives: 2010 Camaro 2SS/RS
Spark Plug Change
Hey everyone, just curious if anyone knows if there's a recommended time vs mileage interval for changing out spark plugs in their gen 5 camaro. I have a 2010 with just over 19k on the odometer. I know 19k is hardly enough miles to change plugs, but they're original factory plugs. Being that they are 14 years old, should they be changed regardless? Thoughts? I think I'm probably just looking for something to tinker with...lol
Motopsycho is offline   Reply With Quote
Old 06-09-2024, 01:55 PM   #2
bsn
Drives: 2013 ZL1
If its running fine don't worry about it.
bsn is offline   Reply With Quote
Old 06-09-2024, 02:14 PM   #3
AlisoBob
Drives: Camaro 2SS Gen 5
If you ever want to get the plugs out of the heads without ruinung the threads, I would worry about it!!!
AlisoBob is offline   Reply With Quote
Old 06-10-2024, 05:24 AM   #4
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
No joke!
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 06-10-2024, 05:36 AM   #5
102SS
waiting at the tree
102SS's Avatar
Drives: SIM 2010 2SS/RS A6
NGK or Denso Iridiums are your best choices unless you plan to run nitrous.
Make sure you put a bit of anti seize on the threads.
2010 2SS/RS A6 Just a few bolt-ons and appearance doo dads
102SS is offline   Reply With Quote
Old 06-11-2024, 04:49 PM   #6
bsn
Drives: 2013 ZL1
The newer plugs are plated-DO NOT USE ANTI-SIEZE!
Old 06-12-2024, 06:42 AM   #7
102SS
waiting at the tree
102SS's Avatar
I learned something new today
It really won't hurt anything unless you slather it everywhere but it looks like it is no longer necessary.
" Should You Put Anti-Seize on Spark Plugs?
The safe answer is “no,” especially if you have pre-treated spark plugs.
Some spark plug manufacturers advise against using anti-seize because they produce pre-treated spark plugs. That means they’ve already been doused in anti-seize properties."
Old 06-12-2024, 07:56 PM   #8
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
This is almost a, "when should I change my oil", question. Look, if you're pushing 70 years old or old school like me, change the MF-ers whenever you want. I was in a similar situation where my car was 9 years old with the factory plugs, but it only had 36,000 miles on at the time, but I changed them anyway.
No, I didn't need wheelie bars after and it didn't make a world of performance difference. But I felt better about it and if that's what you're after, I highly recommend it.
Moto-Mojo is offline   Reply With Quote
Old 06-12-2024, 08:01 PM   #9
Moto-Mojo
Moto-Mojo's Avatar
And by the way, NONE of them fought me on the way out. In fact, some were loose! I did not put any lube / anti seize at all on the new ones. Based mostly on advice here.
Old 06-13-2024, 03:33 AM   #10
102SS
waiting at the tree
102SS's Avatar
I did mine at 65,000 miles Denso Iridiums and yes I used a dab of Anti Seize.
Old School 66 year old retired guy here
Now get off my lawn
Old 06-13-2024, 06:17 AM   #11
ABM2SS
Drives: 2010 SS M6 ABM
I change mine at 100,000 intervals. Just replaced them as I am approaching 300,000 miles. The set that I took out still looked fine. Buy new Plug Wires before you start replacing them. I haven't figured out how to remove them without destroying at least one or two of them. They like to stick to the Spark Plugs.
ABM2SS is offline   Reply With Quote
Old 06-13-2024, 10:55 AM   #12
AlisoBob
Originally Posted by 102SS View Post
I did mine at 65,000 miles. I used a dab of Anti Seize.
Anti-Seize = WIN
Old 09-03-2025, 09:37 PM   #13
eaglescout1824
CamaroNut
eaglescout1824's Avatar
Drives: 2012 Chevrolet Camaro LT RS White
Hi! I have a 2014 SS and I’m at 70,600 miles. I don’t know if they are the original spark plugs but I ordered all 8 new 41-162 AC Delco Iridium plugs. Haynes stated they should be replaced at 72,000 miles while the owners manual states 165,000 miles. I am having a bipolar argument between, “if it ain’t broke……” and “an ounce of prevention……”
What are your thoughts?
eaglescout1824 is offline   Reply With Quote
Old 09-04-2025, 01:29 AM   #14
The SS Godfather
The SS Godfather's Avatar
Drives: TBS BLOWN/CAMMED 2010 CAMARO RS/SS
100,000 kms BUT if any engine works for sake few $ just replace....just did a set on my LS at 42k
The SS Godfather is offline   Reply With Quote
