![]() Drives: Z/28 Join Date: Feb 2022
Running 325 square setup?
Is it too wide? Speedo affected?
Thanks. |
Looks like its been done, not sure why you would need that wide of a tire on the front. Should not effect anything as long as the tire diameter is within 3% and in this case you be ok.
https://www.camaro5.com/forums/showp...04&postcount=4
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM |
![]() Drives: Z/28 Join Date: Jan 2015
Just depends on brand of tire. Some 325 are narrower than others.
Thanks, y'all! Maybe 315 square or just stay OEM 305. Just like the wider look...
Probably will go with MPS4S tires. |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
MPS4S are an EXCELLENT choice. I run 305/30/19 as they're the factory size and I like the ever so slight stretch. I throw the car around quite a bit on the street and I dabbled in Auto X with them. Great all around tire.
#6 |
I run 325 on the stock rear wheel and it definitely helps, I think a 315/325 setup would look great!
2014 1LE - Sold
#7 |
![]() Drives: 14 Z/28 #368 02 SS(sold) 2018 ATS-V Join Date: Jul 2019
I was thinking about going 325s all around as well. Will research some more.
2014 Z/28 #368
#8 |
Thanks for the feedbacks.
I thought that optimal performance is a square setup for our cars? |
#9 |
![]() ![]() Drives: 2015 Z/28 #0058 Join Date: Apr 2018
https://www.camaro5.com/forums/showt...=593123&page=2
Numerous other fellas have done 325 square too
Current:
- '15 Z/28 #0058 | White | A/C | Speakers | Michelin PS4S 305/30/19's - '22 Ridgeline RTL | White | Ebony, '22 CR-V EX-L Hybrid | White | Ebony Sold: - '15 Z/28 #0048 | White | A/C | Speakers | Michelin PS4S 305/30/19's https://www.instagram.com/__jon__athan__/ |
#10 |
![]() Drives: 2015 Z28 Join Date: Feb 2022
I found the turn in better running 305/315 front and 325 rear ...... but for ultimate grip you cant beat 325 all round IMO.
If I wasnt using it on track it Id probably drop back to the narrow front as it was a bit nicer to drive :thumbs: |
#11 |
![]() Drives: 2015 Z28 Join Date: Dec 2014
I put 325's on all around a couple of weeks ago. No issues.
"Resale value is my beneficiaries problem...unless they can bury my in my Z...problem solved."
#12 |
![]() Drives: 2015 Z/28 #1047 White/AC Join Date: Apr 2017
#13 |
Again, thanks for the info and help. Much appreciated!
