2010 camaro ss power steering issues
Just wanted to update for future readers
Replaced the power steering pump and rack and pinion with new oem and went back to the stock cooler by cutting the line from the rack and using 3/8 barb and tranny cooler line to make a new line to the cooler, after a few pita minutes bleeding the system, it now works again Been fighting this issues for awhile now, figured it was time to post up and see if anyone else might have some ideas as this issue is starting to wear on me lol Short story: awhile back removed engine and tranny to do some work and put back in, after reinstalling i forgot to add power steering fluid before firing it up, ps pump took a crap, replaced with a cardone pump from rock auto When i turn the steering wheel either all the way to left or right about 1/2 way it shudders (for about 1/4 of a turn then seems to smooth back out somewhat Reservoir was full of bubbles and boiled over so after some more trying to bleed new pump failed, did find a small leak on reservoir return line crimp, so bought a after market cooler and reconfigured stock line to new cooler, and got a replacement cardone pump Still having same issue, just now without air bubbles in reservoir First thought was might need to replace the rack, or maybe the rack still has trapped air maybe Thanks
2010 Camaro SS M6 my new found headache
![]() ![]() ![]() ![]() Drives: 2010 2SS/RS A6 Join Date: May 2019
Air in the system,it can be many many days.
Btw.What oil you use in reservoir ? |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Jacket up the front end and work the steering lock to lock.
Of course, new doesn't mean good. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
Why did you use Cordone instead of AC Delco?
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
![]() Drives: 2011 2SS, 2006 GMC Sierra Join Date: Jul 2019
You need to put a vacuum on the system to pull all the air out, The shudder is air in the system. You would need an adapter for this, Make sure the level is at the bottom of the filler neck and put 7-10in of vacuum and let it sit for 5-10 minutes, Then top off and put 15in of vacuum on the system while turning the wheel back and forth. Check the level and adjust, start the engine and check for assist and noises, repeat if necessary
#6 |
![]() Drives: toyota thunder Join Date: Dec 2023
It seems you have gone through many things with the steering power system! You have already replaced the pump and sealed the reservoir leak, which means that the air may still be trapped in the system, especially if the bleeding process was not thorough. Don't forget to follow the right way for the Mechanical steering system to be bled completely; in some cases, after a few times you turn the wheel from side to side fully, the air gets out. Moreover, if the shuddering still exists, you should also examine the steering rack and hoses that the steering rack is connected to, they might have been damaged or have blockages. For those who have already tried everything else and are desperate for a solution, replacing the rack may be the real problem as it is likely to be a contributing factor.
#7 |
Sorry for the delay in response, life, i have tried jacking it up, and working side by side with no change in results, initially used atf as thats what always used, but drained and tried ps fluid,
I have tried to find a ps flush kit that had a adapter that would fit the reservoir, but they all seem to be universal plugs that need held in place, think someone would make a twist on cap…. Cardone was on in stock, and didnt want to wait as was trying to fix asap Might go ahead and replace rack, as just want to get the car fixed, so it not just sitting in the garage lol
#8 |
![]() Drives: CHEVROLET CORVETTE STINGRAY 2014 Join Date: Dec 2024
Could the issue be with the rack itself rather than air in the system? Since you've already replaced the pump, cooler, and reconfigured the lines, it might be a good idea to check the rack. Additionally, would it be worth trying a different brand of power steering pump or reservoir to eliminate any potential compatibility problems?
#9 |
![]() Drives: 2010 Chevy Camaro 2SS coupe (MT) Join Date: Jan 2024
Sorry for thread grave-digging…
OEM power steering pumps for the 10-12 SS have become scarce this year, and they’re mostly all generic aftermarket units, or are rebuilt “equivalents”, like Cardone (what the OP had gotten). Even the parts for the power steering, like the pump mount and pump pulley, are discontinued. Vendors are trying to sell those parts individually for as much as $100+… which I think is pretty high/expensive. Yes, they’re “billet” and all, but… idk. Anyhow, I went and got a salvaged OEM unit with about 68k miles on it or so. I paid around like $170 or so, and went with it, as it was the only one I could find. After installing and bleeding, it kept making noises here and there, and would also have tight spots in the steering. I decided to just get a super cheaper aftermarket pump on eBay, for as cheap as like $65. Same exact thing ended up happening, although it was a bit quieter, surprisingly. I decided to once again try for a higher quality unit, so I went with a new Cardone one for about $160. The steering issues finally went away, but then it made an absolutely loud and consistent supercharger-like whine above around 2800+ RPM’s. No matter how much I tried to bleed the pump with the steering wheel (on and off the ground), the noise wouldn’t go away. I ended up driving it for this past year and basically joked with everyone saying I had a supercharger (legit sounds kinda like one, just a bit quieter). Finally pulled the plug and decided to just buy some backstock OEM AC Delco unit off of an eBay vendor and installed it. Problem solved, and I have more peace of mind that it will hold up more, with my occasional hoonigan shenanigans. lol The entire time, I ran mostly a blend of generic PSF (power steering fluid) or fully synthetic ones, which were some kind of LV (low viscosity) formula, kind like the newer ATF’s; although the synthetic PSF’s were kind of leaning towards more of the modern and more common electric power steering units. Didn’t wanna spend $500-700 on a Turn One PS pump, nor a $900+ setup from Lingenfelter. This is as good as it gets unfortunately. I kinda wanted a 2013+ model for this particular reason, as I occasionally take my car to drift events and such. I am also kinda worried about the return line that goes to the reservoir from the bottom left side of the radiator; although I’ve been looking at alternative ones from other cars with hydraulic PS systems. I pulled the plug and randomly bought a return line to the reservoir, from an 08-13 Corvette C6 base (LS3), but it didn’t fit super great. I ended up wrapping some cut up rubber hosing and zip tying it around for noise insulation, and to prevent it from rattling and hitting the chassis. |
