Old 06-21-2024, 03:52 PM   #1
SS_Dave
SS_Dave's Avatar
Drives: 2011 Camaro 2SS/RS
Coilover characteristics
for those who have swapped to coilovers and lowered an inch, would you say it's possible to come away with a better than factory ride?
SS_Dave is offline   Reply With Quote
Old 06-21-2024, 04:37 PM   #2
Indian_Mack
Indian_Mack's Avatar
Drives: 2013 Chevy Camaro 1LT
I've just done this swap on my 13 2LT. I'm still dialing in the spring tension, but so far it did seem a bit more comfortable over bumps than the stock setup.
Really depends on what you're looking for. I tracked the car on stock springs, and it did ok. My impression so far is that the coilovers would perform better on track when adjusted for it.
Indian_Mack is offline   Reply With Quote
Old 06-21-2024, 08:02 PM   #3
SS_Dave
SS_Dave's Avatar
Sounds good. What I'm really looking at is refreshing various things like control arms and others. Looking to lower a little and improve the ride. And I'd really like to make it feel lighter in the front. I also have a Cadillac CTS Vsport with the Alpha chassis and that thing feels a lot more nimble.
Old 06-23-2024, 09:46 AM   #4
Bee
Bee's Avatar
Drives: SS/RS - Rally Yellow
The main reason I went with coilovers was for their adjust-ability in both height and damping. Although I haven't messed with the height since the initial install, it's nice to know I have the option to raise or lower the car if I ever needed to. I am roughly 1.25" lower than stock, which I think it right in the sweet spot.
The damping settings is really where coilovers shine. For the most part, I usually have mine set about in the middle but leaning towards the softer side. If I start to go towards the harder settings, the wonderful roads in PA will force me to dial them back. But the nice part is you can really make them as hard or soft as you want to match your own driving needs and/or road conditions.
Check out my build here.
SEPA5 South Eastern Pennsylvania 5th Gen Camaro Club
Bee is offline   Reply With Quote
Old 06-23-2024, 10:37 AM   #5
Indian_Mack
The front and rear set I got came with front control arms as well. I also figured out by making a trip to the dump that the car is about 100 pounds lighter after the upgrade.
