Old 06-25-2024, 07:49 PM   #1
kevsbumblebee
Drives: 2010 Camaro 2SS
CYLINDER DEACTIVATION- SOLENOIDS?
HELP WANTED.
Got the codes; P3401, P3425, 3441, 3449 and with them a lean condition as when these codes occur the injectors to the cylinders shut off. Also noting a MAF sensor code P0102 but not sure if its related to AFM at all.
All are described as being part of the cylinder deactivation system with each code corresponding to a different AFM cylinder.
Has anybody ever changed the valley cover with solenoids and fixed the problem? Where should I go from here? New to a car with the AFM system so its a bit beyond me at this point. Anybody with superior knowledge on this would be very much appreciated because I don't even know where to start.
-Kevin
kevsbumblebee is offline   Reply With Quote
afm, cylinder deactivation, maintenance, service stabilitrak
