![]() Drives: 2010 Camaro LS Join Date: Dec 2015
ISO: AC Delco 12644532 Heater Hose
For a 2010 V6 LS. Mine has rusted out causing a full coolant leak.
![]() This part has been discontinued...apparently its a thing the car companies are doing now. Any help locating or leads to places that might have this would be great. Yes I tried RockAuto. Are there any US dealerships that might have one? Thank you, Derek |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2LT/RS Join Date: Mar 2015
Try this place. They have salvaged vehicles you can order parts from and they will ship it to you. https://www.hawksmotorsports.com/salvage-cars/camaro/
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can. |
![]() Drives: 2011 2SS, 2006 GMC Sierra Join Date: Jul 2019
Ill look in my GM network and see if there is any more available
#4 | |
Did you ever find one? Haven't seen you reply back in the thread.
2010 2LT/RS
#5 | |
![]() Drives: 2010 Synergy Camaro Join Date: Apr 2023
Also wasn't aware that GM was declaring war on existing Camaro owners, might have to revisit whether or not I keep this thing, especially since a whole raft of OEM replacement parts I was attempting to snag for future use are disappearing on a monthly basis. Update: Some guy on a V6 FB group mentioned that there's supposed to be an updated pipe/manifold assembly and matching hoses, but I haven't seen any mention of them anywhere, so I started searching through Rockauto in regards to other GM cars that use the 3.6 engine, and I sorta found this: https://www.rockauto.com/en/moreinfo...t=6892&jsn=992 It's off of the Cadillac CTS 3.6 Turbo car, and as of fifteen minutes ago shows to be still available. I ordered one just to be a jerk, in the hopes that I'll discover yet another part that GM discontinued. Yes, the Caddy part is a shorter piece, but at least it's new, the base is intact, and there's some piping to work with in regards to making something to work with as a foundation, as opposed to attempting to try to work with something that's rusted through. Last edited by Unaf-Ford-able; 09-19-2024 at 03:43 AM. |
