Old 07-22-2024, 06:22 PM   #1
Toronto
Toronto's Avatar
Drives: 2010 Camaro 1SS
Question Questions about running spray and what’s needed
Looking to start spraying my 5th gen
it’s already h/c looking for more power
phastek has this kit https://www.phastekperformance.com/n...0-10119-90-15/
and i know ill already need a new throttle body plate because im running 102mm TB & intake mani
i’m also looking at grabbing the extra purge lines to do a hood exit purge for “extra” cool points…
but besides the kit (and the adapter plate i need) what else is needed to start spraying? of course besides a tune. looking to spray 150 shot since that seems like a generally “safe” amount.
thanks for the help y’all
Toronto is offline   Reply With Quote
Old 07-22-2024, 06:58 PM   #2
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Plugs are #1. I would run a LNC 2000 or similar to pull timing for spray.
Anything done with your fuel system? Not sure what a factory fuel system is good for.
Old 07-22-2024, 08:33 PM   #3
Toronto
Toronto's Avatar
seems like i at minimum need a zl1 fuel pump and bigger injectors..
i dunno what injectors are needed
is a fuel cell needed?
Old 07-22-2024, 10:09 PM   #4
CamaroDreams76
At a 150 shot you will be fine as long as you have the injectors and pump. A bigger shot like 200/250 and up I would definitely do a dedicated fuel cell.
Injector wise no idea. I ran FIC 660s for my heads/cam setup due to running E. I know ID1050s would have plenty of growing room.
Old 07-22-2024, 10:10 PM   #5
Toronto
Toronto's Avatar
got it. i’ll talk to my mechanic a bit further in the next coming weeks.
thank you
Old 07-23-2024, 11:09 AM   #6
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
The kit you identified is a wet kit. You only need to change injectors for a dry kit, i.e. no fuel solenoid.
ZL1 pump can safely do 550-600whp. I ran a 150 shot with a ZL1 pump, BR7EF plugs and pull timing with an LNC2000. No tune needed.
150 shot, nitrous, nos, spray
