Old 07-24-2024, 09:22 AM   #1
GrandAmGT
GrandAmGT's Avatar
Drives: 2010 1LT & 2016 Cadillac CTS V6
Oil in Spark Plug Tube. New Cylinder Heads?
Hello, Camaro family. I have a 2010 with the V6 LLT engine, and it has 98,600 miles on it. A few weeks ago the car started misfiring while I was driving, it was idling rough and was hard to start. My code scanner detected DTC P0300.
I took the car to a Chevrolet dealership and they said that there was oil in the spark plug tubes and on the spark plugs that was causing the misfires. The dealership said that I need to replace the cylinder heads at a cost of $8,000. They further said that there was a manufacturing problem with the heads that caused them to become porous, thus allowing oil to seep into the spark plug tubes. I found this TSB that describes the issue across a wide range of GM vehicles: https://static.nhtsa.gov/odi/tsbs/20...29900-9999.pdf
Has anyone encountered this problem? Is replacing the cylinder head really the only permanent fix? Thank you.
GrandAmGT is offline   Reply With Quote
Old 07-24-2024, 09:49 AM   #2
gtstorey
I guess it depends on if they eliminated the seals as the leak point.
And how long does it take to build up oil enough to cause a problem. For $8k, you could clean it out and swap plugs a lot of times.
And $8k seem like a lot for replacing heads if needed. Looks like parts are about $2k.
Find a good independent shop to take it to.
Old 07-24-2024, 10:34 AM   #3
GrandAmGT
GrandAmGT's Avatar
Thank you for your advice. The dealership service tech did offer to simply clean the spark plugs and tubes to get the car running again, but he said this was a temporary fix. I was thinking that the problem was not occurring over 98,000 miles, but that it started happening recently due to the age of my car. That's the question: How fast is the oil seeping in? If it was happening over 98,000 miles then I'm good to go with just a cleaning. But if it started happening over the last 1000 miles, then that's really bad. Regardless, I'm going to see an independent shop for a second opinion.
Old 07-24-2024, 10:35 AM   #4
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I agree with gtstorey. I would find a good a good independent shop and get
them to give you a diagnosis and a quote and not tell them what the dealer told you and see what they say.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 07-24-2024, 10:51 AM   #5
gtstorey
No way of knowing how long it will take to start causing a problem but it's probably somewhere between 1000 and 98,000 miles. Only way to know is to clean it up and see how long it takes to become a problem.
Old 07-24-2024, 11:18 AM   #6
DirtyDirt
DirtyDirt's Avatar
Drives: 2013 Camaro ZL1
i agree with morepowerjoe on taking it to an independent shop and getting their diagnosis and quote, without telling them what the "Stealer" said... lol, they call them 'Stealerships" for a reason
2010 2SS SOLD 10-28-23
2013 ZL1 BOUGHT 10-29-23 With 1950 miles
K&N Full CAI
15% tint
Borla ATAK Cat Back Exhaust
Pedal Commander
Headers and Tune
DirtyDirt is offline   Reply With Quote
Old 07-24-2024, 05:41 PM   #7
PaulsSS
Drives: 15SS Camaro
just went through this on a Saturn. Few of the spark plug holes had filled up with oil. Of course would never fix such a obvious poor engineering problem. We cleaned the holes out with paper towels and alcohol new plugs and so far no more trouble. I recommend switching to high mileage engine oil. May help some as its thicker. You don't know till you clean every thing up how long it will take to fill up with oil again. May take another 100k?
PaulsSS is offline   Reply With Quote
Old 07-24-2024, 09:32 PM   #8
InFiD3ViL
InFiD3ViL's Avatar
Sweet Jesus! $8000? You could buy a another used good condition V6 5th gen for that cost. That's actually fairly close to a decent condition high milage SS. Not quite, but close.
Old 07-25-2024, 08:33 AM   #9
GrandAmGT
GrandAmGT's Avatar
Exactly. I can put that money towards buying another car, and I just may do that if I can't get a more satisfying answer from another shop. The labor quote, alone, was $4000.
Old 07-25-2024, 08:41 AM   #10
gtstorey
I looked up the cost of the heads on a GM parts website and they were something like $900 each. That isn't everything but I don't think the additional stuff would be anything like an additional $2k+. I would think $4K would be more than a fair total cost.
Old 07-25-2024, 09:46 AM   #11
ariZona28
Give speed a chance
ariZona28's Avatar
I know what I'll do if my little V6 develops this problem. Hit 'em with the "Rag Wrench", maybe a little brake cleaner, compressed air, a little electrical contact cleaner for the coil/boot assembly then reassemble and send it! I'd do an inspection after a month or so to see how much oil comes back. No way I'm swapping heads at $2 to $8K. Our cars are getting up there in age and sometimes you need to apply some mechanical work arounds for continued service.
ariZona28 is offline   Reply With Quote
Old 07-25-2024, 11:12 AM   #12
AlisoBob
Drives: Camaro 2SS Gen 5
Buy new tubes, swap them out..... done.
AlisoBob is offline   Reply With Quote
Old 07-25-2024, 12:38 PM   #13
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
I am not to familiar with these engines, but aren't there seals also? I would check the torque on the bolts too.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
acutron42 is offline   Reply With Quote
Old 07-25-2024, 02:33 PM   #14
GrandAmGT
GrandAmGT's Avatar
According to the technical service bulletin I posted the link to, the tubes are integrated into the cylinder heads and are not removable.
