Old 08-04-2024, 10:36 AM   #1
BlackBird1
Drives: Chevy camaro SS
Throttle body hesitation
Hello, Have two questions 1)I was wondering if anybody has had where you step on the gas an the car sputters before getting up to speed? I have cleaned the throttle body a couple of times.
2) Can I go from the original throttle body to a 102 mm throttle body and change the original MAP sensor to 3B sensor? The tuner said that engine couldn't have the volume of air without changing the intake manifold is this correct?
The car is a 2010 SS LS3 manual
Thank you in advance for responses.
BlackBird1 is offline   Reply With Quote
Old 08-04-2024, 12:07 PM   #2
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
Here is a link that will help. This is for a 103mm but pretty much the same concept.
https://gwatneyperformance.com/103mm...ow-much-power/
Have you tried a simple relearn yet to see what happens?
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
acutron42 is offline   Reply With Quote
Old 08-04-2024, 12:28 PM   #3
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
When the Camaro first came out this was a common issue. It's caused by stale air currents in the intake and the throttle body. Getting a ported throttle body similar to this one (https://jannettyracing.com/products/...2015-camaro-v8) will fix the issue and greatly increase throttle response.
A 102mm will not bolt on to the stock manifold so it will have to be replaced but there is no point unless you are planning on a bigger cam or running forced induction anyway.
Old 08-04-2024, 12:32 PM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yep. Says it all right here in GPI's write up.
In conclusion, we have empirically validated our long-held position that a 103mm throttle body on an OEM LS3 intake manifold does not offer any performance benefits.
Not worth it unless you have a bigger manifold to help the TB work properly. Thanks Acutron.. Name:  lod1.jpg
Old 08-04-2024, 12:35 PM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
This is one of the FIRST mods I did, and it really did get rid of my throttle lag. Great investment. I have the VMAX unit on my Camaro, still..
Old 08-04-2024, 02:24 PM   #6
gtstorey
Symptoms are so vague that you could have any number of problems. Is this something that it’s always done.
Why would you want to go to a 3 bar map sensor on a NA engine?
Old 08-04-2024, 02:36 PM   #7
acutron42
acutron42's Avatar
Good points gt. BlackBird1, I would recommend getting a good scan tool on it & see what is going on before randomly throwing parts at it.
Old 08-05-2024, 04:46 PM   #8
BlackBird1
Acutron42; Have you tried a simple relearn yet to see what happens? I have not done a simple relearn. I'll remove the battery cable to reset everything. Also I have no codes indicated on my code reader. I've already thrown money towards a new throttle body so that was a waste. But i am searching for 102 mm intake manifold so the throttle body isn't a total waste of money. I was thinking the 3 Bar map sensor would read more air in the original intake manifold to limit the throttle body hesitation but probably wrong about too. I do have many engine mods planned for the car in the near future. Thank you everyone for for your input and links.
sincerely,
BlackBird1
I would like to
Old 08-05-2024, 05:28 PM   #9
gtstorey
This sounds more like miss from your very basic description of the issue.
MAP sensor reads pressure not air flow or volume. You won't be able to have a reading above 1 bar unless you have forced induction.
