Old 08-05-2024, 03:22 PM   #1
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
A/C Problems. Replace Expansion Valve?
Been chasing an A/C issue with my Camaro like many of us have. Air doesn't blow cold.
Initially I thought blend door based on the popularity of that issue. Took apart everything underneath to find the blend door was perfectly fine.
Replaced evaporator temp sensor. No change.
Evacuated and refilled freon to proper amount. No change.
Changed A/C Schrader valve. No change.
Finally took to an A/C repair shop here in Scottsdale to have them attempt to diagnose the issue.
They evacuated and refilled the system and checked for leaks etc.
They came to the conclusion that the issue is the expansion valve.
I'll attach a picture of the work-order notes from the shop.
Anyway, has anyone replaced the expansion valve easily themselves? I assume it's not that hard based on a quick skim of what I'm reading online.
Any tips or advice would be appreciated!
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger, Monster S Series Triple Disc Clutch | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles | Mickey Thompson ET Street R 305/45/18 |
Tuned by Ryne @ CMS E85: 734rwhp/674rwtq
Jeff_SS is offline   Reply With Quote
Old 08-05-2024, 05:15 PM   #2
bsn
Drives: 2013 ZL1
You will need to pull a vacuum if you open the system. They should have caught the expansion valve when they put the gauges on Abnormally hi high side and abnormally low, low side.
bsn is offline   Reply With Quote
Old 08-05-2024, 10:35 PM   #3
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Makes sense. So I'll have to pull everything out of the system, replace the expansion valve, and then fully recharge the system again.
Hope that works.
Old 08-10-2024, 05:35 PM   #4
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Well I took the time to vacuum the system, replace the thermostatic expansion valve and recharge the system. Really wasn’t too bad replacing the expansion valve with the right 3/8” extensions.
$65 part and a few hours work using the loaner vacuum equipment from autozone and all is well.
Very happy to report that my a/c is working as it should, ice cold, again.
