Anthony S
Drives: 2011 chevrolet camaro 2ss/rs Join Date: Apr 2021
P0121 - dirty throttle body?
Would you guys consider this "dirty" been having a p0320 and today, p0121 code. Both throttle body related. Today while cruising the p0121 code started flashing the CEL at me but when I parked the car and let it idle while I plugged in my code reader. It went away. Cleared the DTC and it didn't come back while idling. Decided to clean my maf(which looked good) and then pulled the throttle body to find this. I panic ordered a new gm throttle body from Rockauto, but now I am wondering if I am fine.
Second question... is there a relearn process for the TBS? I unplugged the battery for a few minutes before pulling any of the connectors.
Follow me on instagram @Cthulu_the_trans_am
https://www.camaro5.com/forums/showthread.php?t=600181 2011 Camaro 2SSRS - Sold No longer a 5th gen owner, but still an enthusiast. Ask me about my Front crash bars! |
![]() Drives: 2013 ZL1 Join Date: Sep 2021
I would cancel the Rock Auto order and just clean the existing TB.
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
That is dirty and should be cleaned for sure, I would clean it before replacing it, use a throttle body safe cleaner. When I swapped mine for a Bo White ported unit I don't believe I did a relearn. A dirty TB can throw codes.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount. |
Anthony S
Cleaned and reinstalled. I will take it for a ride today and go ahead and cancel my rockauto order. Hopefully this clears up my issues, it has been really frustrating.
#5 | |
#6 |
Anthony S
Well... a little update. I cleaned up the throttle body, and the code came right back as soon as I drove it down the street. Research of the P0121 codes seems to point towards 9/10 times it's the actual throttle position sensor on the pedal... so on top of my throttle body that is in the mail, I have a new pedal coming as well. Both GM Genuine... $400 in total from Rockauto. Fingers crossed this is the end of my issues.
#7 |
I'd swap the pedal and start there, maybe send new throttle body out for porting prior to install.
#8 |
Tri-County Camaro SWFL
Throttle position sensor on the pedal. I would have guessed the actual throttle position sensor in the TB. I've had to replace 3 now.
As for relearn, I never even unplugged the battery when I swap the electronic side. I haven't had to do a relearn yet. I also went back and forth between Bo's stage 2 and stage 3 TB.
#9 | |
![]() Drives: 2010 Chevy Camaro 2SS coupe (MT) Join Date: Jan 2024
#10 | |
Anthony S
#11 |
Anthony S
Can anyone chime in here? Brand new GM Genuine throttle body. Same code. It shows sensor 1 TPS malfunction. Can anyone confirm if sensor 1 is the pedal? Or the throttle body? It looks like the issue is the 5v reference, of atleast that is what the scanner is showing is the "red" failure point. I'm not mechanically inclined enough to be able to read this properly... no cylinder misfires detected, and no injector misfires detected after roughly 1000 ignition cycles. I have the pedal coming in the mail tomorrow... so worst case scenario, I install that which should clear up this issue, I just want someone to tell me that is the problem. I like to learn from stuff like this so I want to understand what happened here and what the values mean.
#12 |
I think you narrowed it down honestly. If the TB is brand new AC Delco and you are still getting the same, has to be the pedal.
#13 |
Anthony S
Man... this thing is throwing me for a loop. 1. Installed brand new GM Genuine throttle body. Still getting P0121 code. 2. Installed brand new GM Genuine throttle pedal assembly. Now it's throwing 12 codes all directly related to a fuel pump failure. Any thoughts on this?
#14 |
Anthony S
Loading the parts cannon is starting to get quite expensive. Right now I'm about $700 deep on parts. I went ahead and ordered a new GM Genuine fuel pump assembly that has all the sensors and pressure regulator. I have this car set to be sold to a private buyer on the 27th and I really need to get it sorted.
