Old 08-21-2024, 12:34 PM   #1
hcch
Camaro SS
hcch's Avatar
Drives: 2010 Camaro SS LS3
Range shows dashes
Hi, I just noticed that the range is not showing on the dash, everything else is fine but that.
Any ideas ?
K&N CAI, NGK Ruthenium Sparks
Taylor Cable - 409 Spiro Pro Ignition Wire
Chevrolet Performance axle back
Mishimoto Oil Catch Can, Thermostat, Radiator Hoses
Bilstein shocks and strus
RST Stainless Steel Brake Lines
Drilled and slotted rotos, Akebono break pads
hcch is offline   Reply With Quote
Old 08-21-2024, 06:01 PM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
The "range" ?? In the fuel mileage screen?? Push the button in on the end of the turn signal lever and clear it and see what happens. If in fact that is what you are talking about.
Old 08-21-2024, 11:27 PM   #3
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
Yes, the range is visible when you turn the turn signal lever.
Old 08-22-2024, 10:52 AM   #4
hcch
Camaro SS
hcch's Avatar
Yes I am talking about the mile range, I did punch he button on that page but nothing happens, everything else resets fine and reads ok
Old 08-22-2024, 12:31 PM   #5
DirtyDirt
DirtyDirt's Avatar
Drives: 2013 Camaro ZL1
is it out of gas? so it has no range?
Sorry, i know that isnt helpful, but I couldnt resist...lol
2010 2SS SOLD 10-28-23
2013 ZL1 BOUGHT 10-29-23 With 1950 miles
K&N Full CAI
15% tint
Borla ATAK Cat Back Exhaust
Pedal Commander
Headers and Tune
DirtyDirt is offline   Reply With Quote
Old 08-22-2024, 04:27 PM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Hmmm, well then that's going to be a weird one I haven't seen before!
Maybe try disconnecting your neg battery cable for a few minutes to reset your ECU??
Old 09-10-2024, 05:50 PM   #7
Mouse330
Mouse330's Avatar
Drives: 2011 2SS, 2006 GMC Sierra
You need to put a good scanner and check to see if there are any codes in the IPC or any other module that pertains to this problem. Most systems are monitored and will set a code, Not always setting a light on the dash. There could be a fuel level sensor code stored etc.....
Mouse330 is offline   Reply With Quote
