2015 z28 misfire
I have misfire with flashing engine light when I plug in scanner no codes came up , car feels like it’s lacking power bad
I don’t really lied dropping this car with mechanics ://// Any help advice where I should start wILL be appreciated Car has 24K miles , cam and heads been done with msd intake and katech TB
2015 Z28 #572 BLACK NO AC
![]() ![]() ![]() Drives: 2013 zl1 vert Join Date: Dec 2018
use your scanner and look up the stored codes to see what the code was when it was flashing. could be just a bad fuel injector going out or a coil pack.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
Will do thank you
![]() Drives: 2013 Chevrolet Camaro ZL1 Join Date: Jun 2015
Try to idenify the cylinder. Then get a compression test performed.
Let us know how you make out. |
![]() Drives: Chevrolet Camaro Z28 (2015) Join Date: Feb 2023
all great advices, but why don't you start from the spark plugs?
how many miles and years do they have? have you tried removing them and check them? sometimes the simplest answer is the right one
2015 Red Z/28. Seattle area |
#6 |
6K on wires and plugs , coil pack look stock
#7 |
I will check soon and post what I found
#8 |
![]() Drives: 2014 Z28 Join Date: Jun 2022
You can purchase a cheap inferred heat gun at harbor freight and if you have headers (assuming) start the engine and hit the 8 header pipes coming out of the heads. This may show you which cylinder is the issue, then work from there. Plug wire, spark plug, coil and injector. You can test the coil by swapping to another cylinder and see if the problem stays or moves with the coil.
#9 |
![]() Drives: Camaro z28 Join Date: Mar 2021
I have had those issues but my car always gave a code on what cylinder was missing firing. One turned out to be the plug wire was not fully one. So check that out first.
#10 |
Update
Broken rocker bolt , couple damaged valves , pushrod made grove in valve cover Just got car back last week all new stage 2 cam s lifters Added catch can and some nice valve cover from BTR WHP 552 She rips Yestrday I broke driver side axle in my driveway thank god
#11 | |
#12 |
Thank you , yes soo it already had stage 2 cam w 12k miles when I bought car , made 523 WHP , we’re supposed to install or shop was supposed to install stage 3 cam but by mistake they installed a different stage 2 …. Great shop he told me right away about it and that he would swap it out at no cost. I was just anxious to get the car back and now it runs like it never rain before I mean it’s a beast but unfortunately, I just broke an axle in my driveway
#13 |
Mod it you will not regret
