Old 10-04-2024, 02:07 PM   #1
CarbonFibber
Drives: 2011 Camaro SS/RS
So it's okay to "delete" the oil cooler?
I have a 2011 L99 SS that is dripping oil. My mechanic says that its coming from the oil cooler area, only thing is they don't make the OEM parts anymore. I thought I found one online but it was listed erroneously. Now I'm reading on here that some people just delete the oil cooler, and others replace it with a high performance cooler. I don't race it I just want to drive it without leaking and without spending a ton of money (it's got 140,000 miles on it). If you all could provide some suggestions (including any mfr. part numbers) it would make my day. (And why would it be okay to get rid of a function (cooling the oil) and not have it cause problems? I don't get that. Or is it really just there for track use?) Thanks a bunch.
2011 SIM 2SS/RS, Gray interior
CarbonFibber is offline   Reply With Quote
Old 10-04-2024, 02:29 PM   #2
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Mishimtoto makes an oil cooler relocation.
https://www.mishimoto.com/chevrolet-...2010-2015.html
Or you can delete it for much cheaper.
https://www.improvedracing.com/2012-...dgVglSCtGd9zyi
The actual oil cooler itself doesn't leak. There's little O rings that seal the cooler to the block. Mine is leaking currently but I'm going to tackle that next oil change. Its been leaking since I've cammed my car over a year ago and could never track it down until recently.
You need 4 of these GM 12613165 and 1 of these GM 15203889. Rockauto appears to have these in stock.
Here's a good video.
https://youtu.be/aPKtu9RrEjw?si=-ur1ABvgg183-j7k
Me personally, I'll never delete it because my turbos are oil cooled so I need the oil cooler. I also can't use the Mishimtoto because the cooler mounts where my intercooler mounts. The necessity really beats me. I would keep it even if my car was stock.
Old 10-04-2024, 03:59 PM   #3
TheBrightSide
Drives: 2010 Chevy Camaro 2SS coupe (MT)
I’ve replaced many of the circular gaskets inside of the factory oil cooler “block”, and also the gasket at the oil pan feed; and it seems like a lot also just have outright defective manufacturing, where the surface/face of the block and oil/coolant feed, are warped and just barely uneven.
The only way I fixed this for people who wanted to keep their stock oil cooler setup, was to take apart the cooler block and dry off everything (maybe have a good day in between at least), so that you can apply RTV gasket maker all along the mating surfaces. I personally used ‘90-Minute Ultra Black RTV’ (forget the brand), which worked out for a few of the leaking oil coolers I helped “DIY”.
I probably wouldn’t get rid of the stock oil cooler if you live in a super cold area/region, since the factory oil cooler actually helps to warm up everything that uses coolant (which would include the circulating engine oil in your oil cooler). Removing it isn’t bad at all IMO, but it’s probably not recommended if you track your car or drive it hard often. From what I know, the engine oil temps stay around the same; although I’m not sure if engine oil actually warms up slower (probably negligible). The post above me has a kit for some of the parts necessary after you remove the factory parts to the oil cooler assembly. Most of the parts in the kit can be bought for cheaper, or have an alternative replacement if you look around, so those are some possible options.
The Mishimoto engine oil cooler works with your factory oil cooler intact or deleted, since the main oil feed is through a sandwich adapter at the oil filter feed. There are lots of oil feed block kits for the oil pan, but you want one that has space for the ports to circulate (correct me if I’m wrong). I’ve seen a lot of just straight block-off plates online, and I’m not sure if those work for the oil feed at the oil pan…
Another popular option for aftermarket oil cooler setups, is to have the oil feed come from the oil pan ports. There’s a lot of aftermarket oil cooler kits, which include the oil cooler lines, row coolers, and the oil pan feed adapter. Most of them are non-thermostatic (no t-stat inside oil feed), so I went out of my way to find a thermostatic one, which is a lot more expensive but worth it IMO. I personally run a 200 F thermostatic oil cooler feed, which goes to my oil pan ports; and that is routed to a 25-row oil cooler.
The custom route for oil cooler is a lot more beneficial than just deleting the oil cooler; but most people just get rid of the factory one because of the constant leaking issues (on both low and high mileage vehicles). Some people have issues with the sandwich plate adapter at the oil filter feed, so the Mishimoto kit might not be optimal. However, the setup I mentioned, where the feed goes to the oil pan, is a much more optimal setup, especially for LS-style V8 engines. You’ll also need to purchase a universal mounting bracket for the row oil cooler, which will bolt up to the radiator support, just like the way the Mishimoto kit has it’s oil cooler and mounting bracket.
I purchased a long roll of titanium heat wrap to wrap my oil feed lines in, and to prevent them from wearing out from rubbing/chafing against the chassis and other parts. Aside from that, there’s really not much else to the aftermarket oil cooler upgrade. If you do go with the Mishimoto kit, I would probably recommend to get rid of the factory oil cooler; but that’s just my opinion though.
TheBrightSide is offline   Reply With Quote
Old 10-04-2024, 04:33 PM   #4
Bluebagger06
Bluebagger06's Avatar
Drives: 2012 camaro ss
Did the cooler delete on mine and it actually runs cooler
GPI Powered
Bluebagger06 is offline   Reply With Quote
Old 10-04-2024, 06:29 PM   #5
CarbonFibber
Thank you. This gives me a good place to start. Maybe the rings and gasket are still available for more of a fix than a replacement or delete.
Old 10-04-2024, 07:05 PM   #6
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
I’ve read more than a few posts stating that after replacing all the o rings, leaks were still a problem. Just an FYI.
As TheBrightSide stated, alot of the problem is the manufacturing process of the mating surfaces.
0stones0 is offline   Reply With Quote
Old 10-05-2024, 08:43 PM   #7
Pkeen
Pkeen's Avatar
Drives: 2010 Camaro 2ss/rs, 2008 Avalanche
Deleted my oil cooler 4yr ago when I built my stroker. Runs at the same Temps as before.
2010 Rally Yellow 2ss/rs , M6 ,416ci , K1 rods & crank,weisco -3.0cc dome pistons,.040 head gasket, 11.5 compression,1 3/4" LT ,3" pipes w/x-pipe no cats, Cam Motion cam 239/247 113+3 .621"/604" lift , BTR .660 Platinum dual springs w/Titanium retainers, CAI . Stock ls3 heads,intake,injectors & TB. 515rwhp/500rwtq.
Pkeen is offline   Reply With Quote
Old 10-20-2024, 07:13 PM   #8
RickyC
Drives: 2010 2SS RS
Just did mine this weekend….. only has 4000 miles. It’s been dripping for years. So happy I did this.
RickyC is offline   Reply With Quote
Old 10-20-2024, 10:09 PM   #9
0stones0
It don’t come easy.
0stones0's Avatar
Originally Posted by RickyC View Post
Just did mine this weekend….. 4000 miles. It’s been dripping for years. So happy I did this.
Not to sound lazy here but, could you give me a list of the parts needed to perform this task or a link to a “kit” if that is what you used. Not planning on an aftermarket cooler but just the delete.
Thanks
Old 10-21-2024, 01:38 AM   #10
RickyC
Drives: 2010 2SS RS
Improvedracing.com. They have a kit or individual pieces. You will need the block off plate, which comes with the gasket and bolts, the plug for the coolant outlet on the block and a new GM upper radiator hose from a 2012 SS. I called and talked to Jerry, helped with what I needed and even gave me the torque specs. The pieces are definitely high quality. Hope this helps.
Old 10-21-2024, 08:56 AM   #11
SS_Dave
SS_Dave's Avatar
Drives: 2011 Camaro 2SS/RS
Another 2lbs saved. ;-)
SS_Dave is offline   Reply With Quote
Old 10-21-2024, 11:26 AM   #12
0stones0
It don’t come easy.
0stones0's Avatar
Appreciate the info. Just got off phone with Jerry and order is on the way. Got those torque specs, as well.
Thanks again!
Old 10-21-2024, 11:33 AM   #13
Trawz
Trawz's Avatar
Drives: 2013 Camaro 1LE
I second this.
Got my delete kit, and race oil pan baffles from Improved Racing.
High quality stuff and worked great. I got their block off plate with sensor ports so I can add an actual oil temp sensor to the system.
https://www.improvedracing.com/2012-...elete-kit.html
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Custom Mishimoto Oil Cooler, BMR Tunnel Brace, Custom Dual Mishimoto Oil Catch Cans, MSD Plug Wires, Mishimoto Radiator and Hoses, Melling High Volume/High Flow Oil Pump, Improved Racing Oil Pan Baffle Kit, Improved Racing Oil Pressure Bypass Delete, Improved Racing Oil Pick-up Tube Clamp.
Trawz is offline   Reply With Quote
Old 10-21-2024, 12:42 PM   #14
0stones0
It don’t come easy.
0stones0's Avatar
As far as fluids, does all oil need to be drained for this procedure and also, how much antifreeze needs to be drained from the system?
Thanks
l99, leak, oil cooler
