Old 10-04-2024, 03:31 PM   #1
KaraHasDragons
KaraHasDragons's Avatar
Drives: 2013 Camaro 2SS BLACK
Unhappy Zero Oil Pressure???
Looking to see if anyone has an experience with this- (cause this waiting is killing me anxiety)
A little background on my girl- She's a 2013 SS 1LE, approximately 74k miles. Stage 1 cam, Headers, CAI, Intake Manifold all upgraded as well as pulling the fuse on the Dual Mode NPP exhaust the 1LEs come with. All done 6 years ago. Nothing new. Only regular maintenance. No noises and I am pretty darn observant on that part. Only thing I've had to really get worked on is my AC condenser went out almost 5? years ago and the front bumper replaced 4ish years ago when some ass hat ripped my bumper off when leaving his parking spot in his newly lifted truck with tires that stick out 3" inches from his wheel well (I back into all parking spots).
So Tuesday I was drivin' around in my car. No problems. Picked my kiddo up from school. Took him to the orthodontist. Took him to the barber. THEN started her up to go home and I get a terrifying pop up (ding ding ding from her) message saying Oil Pressure Low- Shut Off Engine. I look down at my cluster and the oil pressure gauge was reading ZERO. So I shut'er off.
Got it towed to my house, made sure there was no fresh oil on the pavement where I parked, made sure there was no oil marks in my driveway where I park everyday and then pulled the dipstick. Nada, nada and a fine level.
Got her towed to my mechanic and they hooked up a manual oil pressure reader and it's reading zero.
Has ANYONE ever dealt with this? Any clue or insight to provide while I'm stressing at work, twiddling my thumbs? TIA
KaraHasDragons is offline   Reply With Quote
Old 10-04-2024, 03:43 PM   #2
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
LS3 are notorious for failing oil pumps and or the pressure relief valve sticking open. This causes a low pressure or zero pressure issue. You probably need a new oil pump. With a cam, it's highly recommended to upgrade the oil pump.
Old 10-05-2024, 02:49 AM   #3
King Nothing
Turning wrenches
King Nothing's Avatar
Drives: 2011 Camaro SS By Berger 11BC21
Try a new oil pressure sending unit, that’s cheaper than doing a whole oil pump and a lot easier.
Sold-2006 Pontiac GTO
M6 1 of 475
353rwhp 353rwtq
Sold-2000 Camaro SS A4 Hardtop #867 of 8913
1 of 103 Bright Rally Red Hardtop SS A4 in 2000
1 of 25 and only SIM Camaro By Berger in 2011 year, 2011 Camaro 2SS/RS M6 By Berger #11BC21
King Nothing is offline   Reply With Quote
Old 10-05-2024, 07:36 AM   #4
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
+1
Old 10-05-2024, 07:44 AM   #5
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
New Pressure switch isn't going to help if the manual gauge is reading zero as well ( Unless they tested it wrong which is a slim chance if they are reputable shop ). I would stop starting it until you drop the pan and Check/Replace the above parts.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 10-05-2024, 09:08 AM   #6
King Nothing
Turning wrenches
If there is no lifter chatter or abnormal noises with the engine running, why would you start down the track of worst case scenario?
M6 1 of 475
353rwhp 353rwtq
Old 10-05-2024, 09:59 AM   #7
Joe.G
Joe.G's Avatar
Well he never said how long he had it running for reading zero pressure, so noise would not always start right away, I would definitely error on the side of caution if mechanical gauge is reading zero . But feel free to test the theory of a bad sensor.
Old 10-05-2024, 12:59 PM   #8
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
1+
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune.
George-CZ is offline   Reply With Quote
Old 10-05-2024, 01:58 PM   #9
King Nothing
Turning wrenches
There should be a chattering or knocking noise even at idle if the engine has zero oil pressure. Changing a sensor behind the intake manifold is a lot easier and cheaper to do compared to an oil pump job and possibly more.
M6 1 of 475
353rwhp 353rwtq
Old 10-05-2024, 02:48 PM   #10
Joe.G
Joe.G's Avatar
I guess the OP needs to choose the route he wants to go, at this point the oil has all drained down and if believes the electronic and manual oil pressure test are both wrong and he doesn't mind replacing the topend then keep starting.
Old 10-05-2024, 02:48 PM   #11
CamaroDreams76
+2
Old 10-06-2024, 03:43 AM   #12
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM #93
I disagree. If there’s truly no oil pressure the damage is already being done before you hear lifter clatter or knocking. I used to build engines professionally for what it’s worth. I’d definitely not discount 0 oil pressure on a mechanical gauge.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter.
‘87 IROC-Z Iroc blue. all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
Old 10-06-2024, 09:41 AM   #13
King Nothing
Turning wrenches
Would you start dismantling the front end before changing a $45 sensor? I’ve had oil pressure sensors either read zero or 100 on the trucks I work on . . . and it was the sensor that went bad and not the engine.
My point is the OP shouldn’t jump to the conclusion that the engine is eating itself and several thousand dollars should be spent before trying a $50 sensor. At least drain the oil and see if there is metal.
M6 1 of 475
353rwhp 353rwtq
Old 10-06-2024, 10:48 AM   #14
Aqua Blue RS/SS
Drives: ABM #93
Yep I would if they legitimately put a gauge on it and it had zero pressure. I understand what you are getting at. If there was no verification that there wasn’t any pressure then swapping a sensor would make sense. With zero pressure, obviously the more you run it the more you are risking serious damage. As was said above the LS3’s are now to have oil pump issues, many of which have been documented right here on this site.
1le, oil pressure
