![]() Drives: Chevy Camaro 2SS Join Date: Mar 2023
Need help identifying fuel hose…
Dropped the tank to install ZL1 fuel pump. No matter what I did I could not get the upper hose\line on the evap canister to release. So I had to cut it to drop the tank. Now I’m having a hard time finding the replacement line. On the line I cut it says “GM6406M Type C - Cooper Standard Automotive”.
Can someone provide the replacement part number, please. |
Well, I found the part number. 92232027. Vapor Canister purge hose right rear. It’s basically the purge line that starts back at the charcoal canister and runs along the side of the gas tank. It’s about 30” long.
Discontinued! Any suggestions? Can I just replace this with a hose and clamps? The current line is a hard line. |
#3 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
Also LeeCParts.com
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
Thanks for the suggestions. I’ve searched everywhere and found nothin. I’m gonna use a piece of fuel line and constant tension clamps.
It’s just a section of purge hose so I’m pretty sure this should work. |
#6 |
![]() Drives: 2011 2SS, 2006 GMC Sierra Join Date: Jul 2019
Its just a vapor line not a liquid line you can run rubber fuel line
