![]() Drives: 2010 Camaro 2ss/rs, 2008 Avalanche Join Date: Jan 2019
High Torque Starter
Hey all ,I'm thinking of replacing my starter, it has 180000 miles on it . What's a good High Torque Starter that won't break the bank? I was looking at the Powermaster PowerMax Plus Starters 9004-9 or CVR Protorque Starters 5414 ? Any input appreciated!
2010 Rally Yellow 2ss/rs , M6 ,416ci , K1 rods & crank,weisco -3.0cc dome pistons,.040 head gasket, 11.5 compression,1 3/4" LT ,3" pipes w/x-pipe no cats, Cam Motion cam 239/247 113+3 .621"/604" lift , BTR .660 Platinum dual springs w/Titanium retainers, CAI . Stock ls3 heads,intake,injectors & TB. 515rwhp/500rwtq.
Come on, I know some of you guys are running a High Torque Starter. No input on what's a good one?
![]() ![]() ![]() Drives: 2011 2SS/RS Join Date: Feb 2016
OEM with a DEI heatshield. i have no issues hot or cold. no need for a thigh torque unless you build a high compression.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels •Vararam Ram Air Intake •Speed Engineering Longtube Headers w/ Magnaflow HF Cats •Bo White PnP Stage 2 TB •GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression •Xpipe w/ Res Delete and NPP Exhaust •Tuned By Anonymous Calibrations •Gen5DIY Mylink Conversion W/ Backup Cam •Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle •Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp |
#4 | |
Yea I've done the add aground and clean the other grounds of paint ,rust etc three years ago and haven't had any start problems. I just thought if I'm going to replace it why not upgrade it !
#6 |
![]() Drives: 2011 2SS, 2006 GMC Sierra Join Date: Jul 2019
You are really not upgrading
