Old 10-21-2024, 10:01 AM   #1
SS_Dave
SS_Dave's Avatar
Drives: 2011 Camaro 2SS/RS
Critical changes for the track
For those that are putting their cars on the track (not drag strip), what are the most critical suspension updates you did. Looking to progressively improve handling on this thing. Parts are worn anyway at over 100K miles. Don't want to spend a fortune, though. I'm thinking coilovers, sway bars, and end links are top of the list. Other critical items?
SS_Dave is offline   Reply With Quote
Old 10-21-2024, 11:07 AM   #2
gtstorey
Solid Rear Subframe bushings.
gtstorey is online now   Reply With Quote
Old 10-21-2024, 11:35 AM   #3
KillboyPowerhead
Drives: 2015 Z/22
2012+ outboard-mount rear sway bar if you have a 2010/11; will require 2012+ lower control arms.
KillboyPowerhead is offline   Reply With Quote
Old 10-22-2024, 02:09 PM   #4
SS_Dave
SS_Dave's Avatar
Day to day ride quality and NVH? Intent at the moment is only occasional amateur tracking.
Old 10-22-2024, 02:11 PM   #5
SS_Dave
SS_Dave's Avatar
2011.
Plan was this kit to refresh the front end
https://www.rockauto.com/en/moreinfo...=15413&jsn=966
along with sway bars, end links, and coilovers.
Old 10-22-2024, 10:44 PM   #6
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Rear subframe bushings are a very quiet part it’s when you do the diff/trans/eng mounts is when parts get loud and drone.
1. Set of sway bars 5mm difference front to back, front being smaller (ZL1 front/1LE rear).
2. Bilstien B6’s save money on coilovers to buy rear suspension parts,
and while your in there get a good set of 1” lowering springs.
3. DSE or BMR rear toe, lower control, and trailing arms (BMR is more budget friendly).
4. Wheels an tires preferably Forged Wheels and a good 200 TW tire.
5. Brakes stay with stock 4 piston SS or upgrade to 6 piston ZL1 or C7 Vette calipers OEM
ZL1 rotors for price or DBA/Giro Disc, rear OEM rotors will be fine.
6. Brake pads now that’s a going to be a personal choice, I run OEM pads on ZL1 setup
and it works pretty good but there’s a ton of room for improvement.
7. Engine oil cooler I would budget for that as well the better you get the harder you’ll run
and the oil will get hot. But that’s a last thing to do are you auto or manual if auto
upgrade your trans cooler.
I remember a post being made that the right suspension parts is akin to adding almost 100hp and it didn’t make sense at first but after I started going down that road it made perfect sense.
I hope this helps cause that’s the way I started an my car is pretty good, just needs a better driver.
Orange Krush II
Old 10-22-2024, 10:45 PM   #7
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
And that front kit is an awesome kit you can’t go wrong with Moog!!
Orange Krush II
Old 10-22-2024, 10:47 PM   #8
SS_Dave
SS_Dave's Avatar
Great info. Thx.
I'm M6, btw.
Old 10-23-2024, 06:16 AM   #9
KillboyPowerhead
Drives: 2015 Z/22
Originally Posted by SS_Dave View Post
2011.
If you still have the original inboard-mount (shorter) rear bar I'd highly recommend the 2012+ longer bar - makes a huge difference. And even after noticing such a big change with the new bar (went from older style, 22 mm hollow bar to newer style, 32 mm solid bar), after adding solid rear subframe mounts I wanna say the difference was once again huge. Minimal if any extra NVH with the solid mounts.
Old 10-23-2024, 12:26 PM   #10
Trawz
Trawz's Avatar
Drives: 2013 Camaro 1LE
This is 100% the route you will end up going down.
However, if you are just starting to get your Camaro out on track or are new to running around a road course, I would suggest mainly starting with good 200 tread wear tires, some high quality brake pads like Hawk DTS70's or Cobalt XR1's, and replacing the brake fluid with DOT4+ fluid.
Get out on track and have some fun and you will soon find what you will want to replace/upgrade. Olblue pointed ya down the right path.
I started tracking a few years ago with my 1LE and have not touched any of the suspension... yet.
It has all mainly been brakes, tires, and cooling mods. Plus some new racing oil pan baffles and a new Melling oil pump.
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Custom Mishimoto Oil Cooler, BMR Tunnel Brace, Custom Dual Mishimoto Oil Catch Cans, MSD Plug Wires, Mishimoto Radiator and Hoses, Melling High Volume/High Flow Oil Pump, Improved Racing Oil Pan Baffle Kit, Improved Racing Oil Pressure Bypass Delete, Improved Racing Oil Pick-up Tube Clamp.
Trawz is offline   Reply With Quote
Old 12-13-2024, 02:15 PM   #11
SS_Dave
SS_Dave's Avatar
BTW, are you lowered any in this pic?
