Old 10-21-2024, 05:58 PM   #1
hcch
Camaro SS
hcch's Avatar
Drives: 2010 Camaro SS LS3
ABS, Park Brake and Stabili Track lights went on
Just today after 2 weeks of not using the car I do not used as daly driver the 3 light came up, the first one was the one on the right side where the tach is, some seconds afther the other 2 came up.
The lastest things I made regarding brakes were changin the all 4 break lines with the RST brake kit from Phastek and put some Motul break fluid the DOT 3&4 one, change the trans fluid with Amsoil ATF and the gear box one as well.
Some year and a half may be 2 now I change the 2 front bearings with 2 Moog ones, even when the stock ones were not making any noise or noticable issue.
I really appreciate your advice, hope is not a crazy issue like the ABS module, car seems to be breaking right and also I do not know if I can drive it normally even with that lights on.
Thanks all
K&N CAI, NGK Ruthenium Sparks
Taylor Cable - 409 Spiro Pro Ignition Wire
Chevrolet Performance axle back
Mishimoto Oil Catch Can, Thermostat, Radiator Hoses
Bilstein shocks and strus
RST Stainless Steel Brake Lines
Drilled and slotted rotos, Akebono break pads
hcch is offline   Reply With Quote
Old 10-21-2024, 06:01 PM   #2
hcch
Camaro SS
hcch's Avatar
I have not change the rear bearings
Old 10-21-2024, 07:19 PM   #3
gtstorey
Really sounds like a possible low battery issue.
But the brake light isn't just a parking brake light. It is usually also tied to at least brake fluid level.
And it could be one problem that the other lights are responding to.
Old 10-21-2024, 07:53 PM   #4
hcch
Camaro SS
hcch's Avatar
here is the image of the cluster the only "normal" indication is the TPMS since I need to change 2 of the preasure sensors.
https://drive.google.com/file/d/1W2q...usp=drive_link
Funny thing is that I drove it after couple of hours and there was no indication. Strange... About the Baterry I change a new AGM one 2 years ago
Old 10-21-2024, 09:17 PM   #5
gtstorey
Battery being 2 years old doesn’t mean it’s good. But I’m just throwing out guesses since no real data to go one. A code reader that can read more than ECM would tell you more.
Old 10-22-2024, 05:12 PM   #6
hcch
Camaro SS
hcch's Avatar
I will check if any code apears so far everything is normal no on indicators, just the skid blinked but I start bit hard and there was some loose dirt on the road.
Old 10-22-2024, 05:32 PM   #7
gtstorey
So, the lights came on while losing traction?
Old 10-22-2024, 05:58 PM   #8
Mouse330
Mouse330's Avatar
Drives: 2011 2SS, 2006 GMC Sierra
So as of right now all the lights are off?
Mouse330 is offline   Reply With Quote
Old 10-22-2024, 07:41 PM   #9
hcch
Camaro SS
hcch's Avatar
No originally they came on while grandma driving mode
Old 10-22-2024, 07:42 PM   #10
hcch
Camaro SS
hcch's Avatar
yes all light off, my quote was to let you know that the track light did came on while driving as the manual mention it shoul. So far no lights are on yet
Old 10-23-2024, 11:16 AM   #11
gtstorey
Probably low voltage issue from starting after setting for extended period. Maybe. Without more to go on, that's my best guess.
Old 11-09-2024, 10:38 PM   #12
hcch
Camaro SS
hcch's Avatar
Hi guys, thanks to all of you that kindly gave me some guidance.
The indications were gone since yesterday, I used the car like 15 days in a row a no issues. The thing is that when I went to scan it the indications were gone again so I am really lost here.
My worst scenario is a faulty ABS module hope that is not the case, then I may be buying all new ABS sensors, but besides that and the battery that I did not check because the indications were off since yesterday.
When I get home I will check the fuses.
I again will appreciate any guidedance.
Old 11-10-2024, 01:34 PM   #13
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
I agree with gtstorey here. These cars do very strange things if the battery is not up to par. Last week I put my key in & it slow cranked then went dead. The key was locked, hazard lights & wipers came on by themselves. I got it started with a jump box & it had a dead miss fire with the abs, stabilitrack, cel lit. I hooked up my ctek mxs 5.0 & in less than 24 hours all was good.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
acutron42 is offline   Reply With Quote
Old 11-10-2024, 02:23 PM   #14
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM #93
Yep me too battery is definitely the first place I’d check. When mine was on the way out it did all kinds of weird stuff. The remote start wouldn’t work most of the time, then I started getting the traction control, abs etc. lights that would come on when starting then go away after a few minutes of running, and a few other things. If you’re driving it consistently and it’s not giving you issues it’s most likely because your battery is staying charged to a level high enough to keep the electronic systems happy. Once you let it sit the weak battery starts to show its face.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter.
‘87 IROC-Z Iroc blue. all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
