Old 10-23-2024, 03:50 PM   #1
mactube
Drives: 2015 Camaro Convertible
Theft deterrent system reset
My Theft deterrent system light is on the dashboard, and the car doesn't start. I have heard that you have to try multiply times to leave the key in the on position for 10+ minutes but the car still wouldn't start.
Does somebody have another idea ? I'm trying to avoid have to tow it to the dealership for a reset.
2x 2015 Convertible 1LT
- White on Black 22”s
- Silver Stock
mactube is offline   Reply With Quote
Old 10-24-2024, 09:52 AM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Disconnect your negative battery cable for about 30 minutes or so, it will reset all the systems when you reconnect it. You will though have to re-index your windows, and reset your time and date on the radio.. Good luck..
Old 10-24-2024, 11:03 AM   #3
gtstorey
Always possible that you have had an actual hard failure in the system. Failed module, damaged wiring, failed key etc.
Old 10-25-2024, 04:44 PM   #4
Mouse330
Mouse330's Avatar
Drives: 2011 2SS, 2006 GMC Sierra
You need a scanner that will access the BCM(Body Control Module). Likely a failed component.
Mouse330 is offline   Reply With Quote
