Old 11-12-2024, 09:33 PM   #1
11/SS/RS
11/SS/RS's Avatar
Drives: 2011 Camaro 2SS/RS
Brembo Caliper Decals
So replacing my rotors, pads and also replacing the rubber brake lines with a set of stainless steel lines. A few of the decals are somewhat worn off of the ccalipers. I would like the same white and red lettering.
Where is a good place to source them and what procedre should be done to do it correctly?
2011 SS/RS K&N Cold Air Intake, Borla Atak Cat Back, Ferrada CM1 Wheels, ZL-1 front spoiler, JSD strut tower brace, Elite Engineering catch can, Baer Rotors & Pads, Stop Tech SS Brake Lines. More to come...
11/SS/RS is offline   Reply With Quote
Old 11-13-2024, 06:35 AM   #2
SL33P3R
SL33P3R's Avatar
Drives: 2013 Camaro SS Vert
Look for high temp vinyl on Amazon. Had mine for years with no issues. They actually out lasted the G2 paint.
SL33P3R is offline   Reply With Quote
Old 11-13-2024, 08:35 AM   #3
11/SS/RS
11/SS/RS's Avatar
They only seem to have the Chevrolet lettering in black and the Brembo lettering in white.... Cant find it in white and red like the originals
Old 11-13-2024, 10:32 AM   #4
SS_Dave
SS_Dave's Avatar
eBay
I bought these. No issue.
https://www.ebay.com/itm/224167454618?var=522975846037
SS_Dave is offline   Reply With Quote
Old 11-13-2024, 11:56 AM   #5
DRC69
DRC69's Avatar
Drives: 2011 2LT/RS
I was looking at this listing on the Bay.
https://www.ebay.com/itm/114971346108?var=415086425253
Do you think you need to spray a clear coat over the decals?
DRC69 is offline   Reply With Quote
Old 11-13-2024, 06:52 PM   #6
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
They say you should spray clear over the decals/calipers to make em last longer. How long have you been using these decals for?
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 11-14-2024, 10:29 AM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
When I originally painted my stockers with the G2 caliper paint kit, and put new decals on them, I did spray them with a coat of hi-temp clear to protect them, and keep them clean.
Old 11-14-2024, 09:37 PM   #8
11/SS/RS
11/SS/RS's Avatar
ok so check on the clear coat, Ill use a matte clear if I can find it.
Old 11-15-2024, 01:45 AM   #9
InFiD3ViL
InFiD3ViL's Avatar
Originally Posted by SS_Dave View Post
Yep, Ebay has pretty much any combination you can think of. It's where I got mine both times.
Old 11-15-2024, 04:01 PM   #10
DRC69
DRC69's Avatar
Drives: 2011 2LT/RS
Question
I have not used them. I bought all new PowerStop Brembo F & B to do the upgrade on my V6.
They have powerstop decals on them now. I was thinking on removing them just not sure yet.
Old 11-16-2024, 08:36 AM   #11
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
I purchased like 6 sets of Decals from a vendor on Ebay as I was nt sure what color I wanted to go with, My ZL1 calipers were in nice shape for the most part but the front's had some issues so I scuffed/Sanded those areas and I painted from the caliper split line forward ( Front half of caliper ) as the backs were perfect and then applied decal and then cleared.
I used Hi temp paint and clear, Id have to go out to the garage to see what brand I ended up using as the VHT Satin and Matte Hi Temp clear was giving me issues spraying blotchy and I tried a couple cans. I believe I ended up using a Gloss Black which I then toned done with either a Satin or Matte clear.
I did Ceramic coat the calipers and both rears gave me a little trouble they were turning purple but I was able to clear that up with a lot of polishing, I then waited longer and re ceramic with a different brand and all was good.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 11-16-2024, 08:46 AM   #12
Joe.G
Joe.G's Avatar
Here are some pictures
