Old 11-16-2024, 02:24 PM   #1
TBronk16
Drives: '22 Chevrolet Camaro 2SS 1LE M6
Speedometer and Tachometer needles stuck at 0
My Speedometer and Tachometer needles are stuck at 0 when I start my 2010 SS and they do not work when I start driving at all. Is there any DIY fix to it or do I have to buy another instrument cluster?
TBronk16 is offline   Reply With Quote
Old 11-19-2024, 04:32 PM   #2
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
My Tach was stuck on zero and was caused by a bad battery. Never heard of both not working. Any codes?
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 11-19-2024, 04:55 PM   #3
gtstorey
More than likely any codes for this would be stored somewhere that a basic "P" (powertrain) code reader wouldn't see them.
Old 11-19-2024, 07:22 PM   #4
InFiD3ViL
InFiD3ViL's Avatar
I have had the issue where either my tach or speedometer, whichever decided to act up that day, would stick at zero. It was always at the same time that I would get a Stabilitrak error. It was my battery. If you try to start the Camaro with less than optimal battery voltage it will usually throw a Stabilitrak error on the DIC, I have noticed.
Occasionally I will get this when I haven't started my car in a couple of weeks.
Old 11-19-2024, 08:10 PM   #5
Bigdumogre
Bigdumogre's Avatar
When my tach wasn't working due to a weak battery it threw a crank sensor code. Always worth a shot to check.
fix, speedometer, stuck, tachometer
