Old 11-18-2024, 09:09 PM   #1
TheBrightSide
Drives: 2010 Chevy Camaro 2SS coupe (MT)
Issues with removing front bumper/fascia?
I have a 2010 2SS with the RS package and factory Ground Effects appearance package. I’ve gone through plenty of 5th gen Camaro’s to know how easy the front bumpers typically are… However, removing mine proceeded to be a full-blown challenge; literally ended with me cracking the snap-in bumper mounts by the head lamps, and I snapped off the two plastic bumper dowels in the middle of the 4, on each side….
Is this unique to certain models or Ground Effects equipped cars or something? My 2010 first year release model, is also a June 2009 production car (can’t recall the exact date). It also looks like those bumper mounts (that cracked) have a rivet where they were installed, which means that they must’ve had to be a factory GM part at some point… I ended up cracking both sides of the typical bumper slots on the plastic bumper, so I JB-weld epoxy’d those back, as well as the cracked bumper mounts.
I’m debating on whether on not to tap some screws through the sides of my bumper, so I can hold the plastic dowels that broke off, to be able to JB Weld them back into place.. Should I eliminate the bumper brackets altogether…? I’ll upload photos in a bit, but it seems that most 5th gens don’t have these, which is why most peoples’ front bumpers literally just slide right off! I don’t wanna be breaking my bumper every time I need to remove it.
TheBrightSide is offline   Reply With Quote
Old 11-18-2024, 09:22 PM   #2
TheBrightSide
- Front Upper Bumper Cover - GM (92236547)
https://www.gmpartsdirect.com/oem-pa...Y4LWdhcw%3D%3D
- Passenger Side Front Bumper Fascia Lower Reinforcement - GM (92243318)
https://www.gmpartsdirect.com/oem-pa...YtMmwtdjgtZ2Fz
Guess I found the issue in one other forum post, where a user referenced to the optional part as a “brace”… Thing is, there’s really no proper way to remove it without nearly cracking off the sides of the bumper. The two clips on the side will pop freely as usual, but then the section that goes into the “support bracket”, has to be taken out a certain way, which will most likely damage and/or break the brackets themselves.
Debating on whether or not to keep these, as it seems to be a huge hassle in my opinion… It does fix the issue with the main weak bumper clip areas breaking. It’s just that the inner bumper clip areas, are hard as hell to get to. Mine are eaten up from me trying to yank the bumper off, which caused it to snag, fall entirely forwards, and then snapped off a tab from the bracket on each side; ultimately allowing the bumper to free itself. LOL
Old 11-18-2024, 09:40 PM   #3
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM #93
Can you post pictures of what you are dealing with? I’ve had 2 2009 built 2010 model year cars, a GFX car and a non GFX car and the bumper removal was the same. Did you take the 3 bolts off on each side that bolt the upper bumper cover brackets with the 3 dowels to the fender? The upper and lower brackets are available separate from the bumper as you’ve likely already found. That lower bracket is bolted in two places one up thru the back corner near the fender liner with a small bolt and another that goes into the fender mount bracket as well.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter.
‘87 IROC-Z Iroc blue. all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
Old 11-19-2024, 06:03 AM   #4
Arogg
A legend in his own mind
Arogg's Avatar
Drives: 2010 2SS/RS M6
Originally Posted by Aqua Blue RS/SS View Post
Can you post pictures of what you are dealing with? I’ve had 2 2009 built 2010 model year cars, a GFX car and a non GFX car and the bumper removal was the same. Did you take the 3 bolts off on each side that bolt the upper bumper cover brackets with the 3 dowels to the fender? The upper and lower brackets are available separate from the number as you’ve likely already found. That lower bracket is bolted in two places one up thru the back corner near the fender liner with a small bolt and another that goes into the fender mount bracket as well.
Pics would definitely help. I have an early (April 09) 2010 2SS with GFX and no issues removing my bumper and I've had it off numerous times. The ONLY issue I ran into last time was one of the bolts holding the bumper to the fender was spinning without getting loose but a pry bar and some ingenuity got it out.
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's / MRR 228 Wheels / BMR Springs / Koni Yellows / R1 Concepts Rotors & Pads
2006 Dodge Magnum RT "The daily"
Arogg is offline   Reply With Quote
Old 11-19-2024, 08:42 AM   #5
TheBrightSide
Yes, if you look up the GM instruction manual (I forget the exact document reference), it shows everything EXCEPT the optional bumper support bracket.
Also, my bad, the support brackets are also BOLTED in. They’re made out of plastic, but have a rivet that allows the bolt to be threaded through. I’m legitimately debating cutting off the front portion of the support bracket though, as that’s what’s preventing the front bumper from coming off in a simple fashionz
Old 11-19-2024, 10:16 AM   #6
MSgt O
MSgt O's Avatar
Drives: 2012 Camaro 2SS/RS Vert LS3/M6
Im just going to ask, did you remove ALL the bolts before trying to pull the front end off?
MSgt O is offline   Reply With Quote
Old 11-19-2024, 12:55 PM   #7
Aqua Blue RS/SS
Drives: ABM #93
I’m lost man. I guess I don’t know what you mean by optional bracket. If it’s the lower bracket you linked above I don’t think that’s optional at all. Could you link the thread you found that references the optional brace and maybe that will help us out?
Old 11-19-2024, 02:04 PM   #8
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
[QUOTE=MSgt O;11454553]Im just going to ask, did you remove ALL the bolts before trying to pull the front end off?[/QUOTE
Did you get the bolts under the hood? It is pretty straight forward.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
acutron42 is offline   Reply With Quote
Old 11-19-2024, 09:40 PM   #9
InFiD3ViL
InFiD3ViL's Avatar
[QUOTE=acutron42;11454605]
Right. I guess it could be easy to forget that there are 3 bolts on each side behind the wheel liner as well. The top ones can be hard to see and even harder to reach. I rounded mine off and had to replace them.
Old 11-20-2024, 08:10 PM   #10
TheBrightSide
Reference forum thread post
Funny enough, it’s a thread you commented in… lol
https://www.camaro5.com/forums/showthread.php?t=614145
Looks like the OP for that forum thread broke the main front bumper clips (part of the bumper itself), and then the ends poke out because they can’t be held back or fastened down anymore.
And yes, I know about all the bolts, guys lol I’ve done this plenty of times. You wouldn’t be able to even get the bumper off without taking off those bolts behind the fender liner, let alone forgetting the plastic clips on top (I forget the name of them).
Old 11-20-2024, 09:30 PM   #11
Aqua Blue RS/SS
Drives: ABM #93
That’s not an optional brace man. It’s the lower mounting bracket. I can’t see how it would have anything to do with breaking the upper alignment pins by the headlights. I actually do have those lower brackets rat holed away like I mentioned in that thread. I just went thru all this bumper stuff about a month ago when I had to replace my front bumper. Without actual pictures of what you are dealing with I don’t think this thread will be of much help.
Old 11-20-2024, 10:13 PM   #12
InFiD3ViL
InFiD3ViL's Avatar
Brightside, Are you the original owner of this car?
If not, have you considered, as stupid as it sounds, that maybe the previous owner super glued the front bumper in some spots? When brackets or mounting points on these cars break the bumper cover will fit kinda wonky and either sag or stick out (like near the side markers), and those with no patience, repair skills, or money for fixing things properly will resort to things like that.
It's an idea at least and would explain a lot.
Old 11-21-2024, 12:18 PM   #13
pyroguy
Keeper of “THE list”
pyroguy's Avatar
Drives: ABM #832
My guess is that the OP missed that one bolt that's way up there and a total P.I.T.A. to access. I too have a 2SS/RS with a ground effects package and I took my front bumper cover off last year without issue.
Check out my build thread
Old 11-21-2024, 12:29 PM   #14
Aqua Blue RS/SS
Drives: ABM #93
Yep that’s been my suspicion all along and why I asked if he got the three fender bolts on each side.
bracket, bumper, fascia, mounting, removal
