Old 11-20-2024, 03:04 AM   #1
Cali_Camaro_SS
Cali_Camaro_SS's Avatar
Drives: 2010 Camaro 1SS (BLACK)
Anyone know what noise this is?
Noise coming from the front left while driving especially when on bumpy roads. Thought something with suspension but then around 3-4 times I’ve heard it while at a light so thinking possibly with a pulley or tensioner. Let me know what you think.
Can’t post a YouTube short vid in here so just click the link
https://youtube.com/shorts/NW_g0KGd2...CRjLjPdwTpty_Z
Cali_Camaro_SS is offline   Reply With Quote
Old 11-20-2024, 07:50 AM   #2
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
It was hard to hear it could be a tension-er but it may be something loose and rubbing. Start the car and look under the hood, I am leaning towards something being loose.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 11-20-2024, 04:13 PM   #3
sports car fan
Drives: 2011 Camaro 2SS/RS Manual
Always find it difficult to assess a sound through an audio recording compared to being there, but (as far as I can tell) I experienced a similar kind of noise. The culprit was the belt for the air conditioning compressor slipped slightly and was basically running on the rim of the wheel. But again, just guessing as could not exactly make out the sound.
sports car fan is offline   Reply With Quote
Old 11-20-2024, 07:00 PM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Kinda hard to tell, but it sort of sounds like a belt/pulley issue.
Old 11-21-2024, 07:57 PM   #5
Cali_Camaro_SS
For sure I’ll check those out. Thanks y’all.
Old 11-22-2024, 02:58 PM   #6
Cali_Camaro_SS
It’s just hard to tell as when I have it parked and open the hood to listen the noise is not there. 99% of the time only when driving.
How can I tell if a pulley is making noise or is bad?
Old 11-22-2024, 06:05 PM   #7
Joe.G
Joe.G's Avatar
that's why I don't think it's a belt or pulley issue it sounds more like something is loosen and making more of a rubbing sound. Can you shut car off and push on body panels and suspension?
Old 11-23-2024, 02:38 PM   #8
Cali_Camaro_SS
Finally got a chance to look under the hood and moved around a few things. I saw a little piece of the cold air intake bracket was kinda moving a bit so tightened it down and only other thing I moved was the hid ballast that was just chillin on metal.
But I’m guessing it was the bracket for the intake.
Thank again y’all.
Old 11-23-2024, 02:41 PM   #9
Joe.G
Joe.G's Avatar
Yeah that's what I figured, glad you found it.
Old 11-23-2024, 05:39 PM   #10
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Glad you found it and it wasn't anything major! Thanks for letting us know.
Old 11-26-2024, 04:55 PM   #11
Cali_Camaro_SS
