Old 11-22-2024, 02:49 PM   #1
2010.2ss.abm
Drives: 2010 Camaro 2LT
AFM Delete L99
Hello, I am preparing to begin the process of swapping my LT Camaro to an SS. I know it doesn't make much sense, "why not buy a SS?" My 2010 LT was my first car and unfortunately doesn't run anymore. I'd much rather give new life to it than buy a replacement. That being said, I will be dropping an L99 automatic into the car. I'd like to disable to AFM to prevent the car from swapping over to 4 cylinders. From everything I've read here and throughout the internet, it seems like this can be done without physical modifications to the engine via tuning. Is this correct? And if I'm not worried about making more power than stock, do I need to bother with VVT or can I tune out AFM and leave VVT as is? I'm trying to avoid as much mechanical modification as possible. Any advice for this noobie over here is appreciated. Thank you!
2010 ABM Camaro 2LT RS #2324/3903
Daily for many years, upcoming 2SS conversion
2010.2ss.abm is offline   Reply With Quote
Old 11-22-2024, 03:53 PM   #2
ss camaro-monte
Drives: 2015 camaro 2ss, 87 monte ss
If all you want is afm turned off any tuner can easily do that but are you putting in a 6l80e with it? Transmission is totally different between the v6 and v8 so I assume a trans tune will be needed as well.
Not sure on power limit of v6 transmissions either. You can check on the v6 forum. Several members over the years have done the conversion. Check in the search box.
Ted jennatty, dyno Steve and gpi are all sources for good tunes online and they can help you with up loading but if all you want is a stock tune I assume the transmission tuning is the most important if your transmission can handle it.
ss camaro-monte is offline   Reply With Quote
Old 11-22-2024, 03:59 PM   #3
ss camaro-monte
Personally if it was me and you figured out all the emissions stuff and didn't want to crack the engine and spend as little as possible I would just tune the stock L99 and trans if you got the 6l80e as well and turn off adm and leave vvt alone. Vvt is a good thing mostly. Just my 2 cents.
The difference between a stock L99 camaro ss and just one with a tune is pretty amazing even if everything else is stock. Changes the whole responsiveness of the motor and transmission.
Old 11-22-2024, 04:42 PM   #4
gtstorey
Are you swapping in the ECM from the v8?
This is never as simple as people hope it will be.
Old 11-23-2024, 02:56 AM   #5
2010.2ss.abm
Yes , I am just looking to turn off AFM. I don’t need/want the car dropping into four cylinders. I will also be swapping the transmission, ECU, and all harnesses from a donor car. I drove my car to 150k miles and id be afraid to try and pair that transmission with the L99, besides all the electrical glitches that may present.
Thank you for the advice. My friend who will be doing the conversion for me seems to thing I will need to mechanically remove the AFM as well? He says that while it can be tuned out, it’s best to remove it physically while the motor is out of the car anyways. Is this true?
Yes, I am picking up a copart donor car and swapping everything over, powertrain, ecu, accompanying harnesses and mounts, etc.
Old 11-23-2024, 12:12 PM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
No, only if you want to and are planning a cam swap to an LS3 cam. I ran my L99 for 99k miles with it just "tuned out" when we did the LT install and custom dyno tune. No issues what so ever! Then at 99k we did the cam swap and AFM/DOD delete.
Old 11-24-2024, 02:32 PM   #7
ss camaro-monte
Jewld is correct. I you turn off afm usually the afm lifters aren't a problem. I have seen L99s with 150k that have never had lifter problems, and then I have seen some with lifter problems after 40k. Luck of the draw. But just tuning it out is what you need to do. If you do remove the afm liters, that is a plus, but if you don't want to spend the extra coin, there is no reason it won't go 100k plus on the motor.
I guess that is my next question. How many miles are on the L99 donor going in?
Old 11-25-2024, 12:55 AM   #8
2010.2ss.abm
Thanks for the advice, much appreciated. I haven’t selected a donor yet, still shopping around copart. I’d ideally like one under 100k miles.
Old 11-26-2024, 08:23 AM   #9
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
If it were me and the motor was out of the car I would go ahead and replace them, it'll be easier and you will have a piece of mind.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 11-27-2024, 12:57 AM   #10
2010.2ss.abm
Thanks, this is my line of thought as well. Any idea what replacement parts I would need after removing it?
Old 11-27-2024, 05:45 AM   #11
Joe.G
Joe.G's Avatar
GPI and many others will have most likely have complete kits, we have a fleet of hemis where I work and we loose lifters at anywhere from 40k and up. The L99 cars are known to have issues as well. It's definitely worth the time and for minimal cost before they go. Once they go you are now replacing the cam and it depends on how bad if you are dropping pan to clean the metal shavings/dust. Buying a used engine you have no idea idle hrs or how it was taken care of. Do yourself a favor and replace the lifters.
Old 11-27-2024, 08:15 AM   #12
2010.2ss.abm
Thanks for the advice!
Old 10-23-2025, 12:24 PM   #13
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
Surely this must be completed by now. Pics!
Moto-Mojo is offline   Reply With Quote
