Old 11-28-2024, 06:06 PM   #1
TheBrightSide
Drives: 2010 Chevy Camaro 2SS coupe (MT)
Upgraded engine oil cooler: increased oil capacity?
I wonder if the typical ~8 quarts for a regular engine oil change, would typically increase; if say, maybe a 25-row oil cooler was installed (ex: Mishimoto engine oil cooler kit)?
I have a few different 10-11 Camaro SS’ that I’ve been working on, that have the older OEM GM engine oil dipstick, P/N 12634547. Looks like the dipstick has been revised/superceded to a newer oil dipstick, P/N 12665298.
I’ve been having trouble measuring the engine oil, even after the car/engine have been sitting for hours. I swear I even added almost 9 quarts of oil to one L99 (with no leaks), and the old dipstick keeps reading inadequately (ex: smudged or inconsistent). I’ve since replaced to the newer oil dipsticks and it looks like I’m still having issues checking exactly what the engine oil capacity should be at…
TheBrightSide is offline   Reply With Quote
Old 11-29-2024, 08:59 PM   #2
econ
Drives: 2013 2ss
Yes, oil capacity will increase but you still check oil the same, with the same dipstick, since the amount of oil available in the sump in unchanged. The added oil is outside of the pan and this does not affect the checking of the oil.
The lines going to and from the cooler plus the cooler itself add oil.
econ is offline   Reply With Quote
Old 11-30-2024, 07:23 PM   #3
TheBrightSide
Yeah, not sure what’s going on, but I’ve been trying to check the oil dipstick for 3 days now, and the reading keeps getting smudged. And if it does reach full or show the level maybe a bit above max, only one side of the oil dipstick has the oil on it.
Old 11-30-2024, 09:22 PM   #4
econ
Drives: 2013 2ss
Not sure how your cooler is set up. Does it sandwich between the oil filter and block? Most do...If this is the case then draining the pan will not drain the cooler and lines.
So, drain the oil pan. Measure how many quarts came out (just in case things get strange and you need to know). Leave the filter. Add 8 quarts of oil fresh oil. You should now be able to get a full reading on your dipstick.
Old 12-02-2024, 05:33 AM   #5
Tommi
Tommi's Avatar
Drives: 2010 Camaro SS manual
If the stick has oil only on one side, the oil came from the dipistick tube. etc. The dipstick was never inside the oil up to that level.
2010 Camaro SS, LS3 + 6spd manual. 1975 Volvo 242, 357SBC + 6 spd manual. 1978 Blazer offroader with LS1, 1-ton axles.
Tommi is offline   Reply With Quote
Old 12-11-2024, 08:09 AM   #6
RoySGrant
Drives: Swift
Ok, thanks.
RoySGrant is offline   Reply With Quote
Old 12-22-2024, 02:39 PM   #7
TheBrightSide
From what I know, others have a hit and miss time with reading their dipsticks on some of the LS engines. However, mine was perfectly fine before, so I’m really not sure what happened… Unless I’m under-filled, I “overfilled” to about ~9-9.25 qts after I ripped out the old oil cooler system and installed my upgraded system.
dipstick, engine, level, motor, oil
