Old 12-02-2024, 03:18 PM   #1
Vegas Black SS
Back in Black
Vegas Black SS's Avatar
Drives: Black 2SS/RS
2013 ZL1 for sale Crystal Red $32,500
General Details
Year: 2013 Mileage 61,800
Model: Camaro ZL1 627WHP (Engine has less than 1500 miles on it)
Color: CRYSTAL RED TINTCOAT
Transmission: Auto/Kilduff Paddle Shift Eliminator
Interior seat/trim color: Black
Package Options: RS package HUD
Exterior Modifications
Wicker Bill Spoiler
Front Rock Guards
Black Taillight Bezel
Black Reverse light Bezel
Wheels: Concept One CSM-5 GUNMETAL 20"/10"-11" Deep Concave Series
Interior Modifications
Sued shift boot
LED Ambient Interior Lighting Kit
JL Sub Box 3-10" subs
Kicker ZX1500.1 Amplifier 1500 Watts
JL Audio C5-650 Evolution Front speakers
JL Audio XDv2 amplifier
Kenwood Excelon XR-1800 Rear speakers
Hushmat installed
Performance/Handling Modifications
LSA Pulley Swap upgrades
2.50/3.5-4.5 lbs. Heavy Duty Isolator Pulley
50 mm Double Bearing Idler Pulley
4.5 lbs./8.5"Crank Pulley
Nick Williams 102mm Throttle Body
Molinar 6.100 Rods
CP Bullet Pistons w/AP Ring set
Clevette Coated Main Bearings
Clevette Coated H Rod Bearings
Stage 1 Hater Cam
Iwis Time Chain Kit
ARP Main Stud Kit
ARP Head Studs
Pac Valve Spring Kit
Johnson 2210R Lifters
Trunnion Kit
Moroso Oil Pump
HD Fleet runner Supercharger belt upgrade
Alky Meth System w/4 gallon trunk mounted tank
Pro Meth upgrade kit 5 nozzle
FIC Injectors 850cc
Moroso PCV Air/Oil Separator
1 7/8" Kooks Long tube headers ceramic coated inside/out (Cat delete)
Afco Heat Exchanger
JLT Cold Air Intake
Big Gulp Air Induction
Roto-Fab Washer relocate kit
160* Thermostat
BMR lowering springs 1" rear/1.4" front
Slotted/Drilled rotors
Goodridge SS brake lines
Larger intercooler pump (30% more flow)
PRO-CHARGER 500 RWHP 465 RWTQ - ZL1 EXHAUST/SPOILER/DIFFUSER/ROCKERS - BC RACING COIL OVERS - 1LE SWAY BARS FRONT/REAR - BMR REAR CRADLE BUSHINGS
Vegas Black SS is offline   Reply With Quote
Old 12-03-2024, 11:18 AM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Very nice! Good luck!
Old 01-22-2025, 03:10 PM   #3
Vegas Black SS
Back in Black
Price drop
Old 02-02-2025, 06:52 AM   #4
gen=5
gen=5's Avatar
Drives: 13 ZL1 vert blac fastlane/LPE 750
So how much power is that making ? As that’s a lot of motor for just 627 rwhp ? As im looking for one, but I had Lingenfelter set up ,and it made more than that on the stock heads and bottom end. With just pulleys and their biggest cam ,and valve train and some porting …I’m sure there’s others, but that’s the first Alki kit I’ve seen that’s been drilling and mounted into the lid ? so im guessing it’s for more timing, and maybe a much smaller pulley ? Seems you’ve got enough motor for well over 1000 rwhp ? Did you blow up the first motor, or just built it for additional plans down the road like porting ,and. Blower upgrade..
http://www.camaro5.com/forums/showthread.php?t=346589 CHECK OUT THE BUILDING OF MY RANCH FOR DISABLED VETS, COMPLETE WITH A GUN RANGE .
gen=5 is offline   Reply With Quote
Old 02-04-2025, 02:12 PM   #5
Vegas Black SS
Back in Black
PM sent
Old 04-21-2025, 02:31 PM   #6
Vegas Black SS
Back in Black
Price drop
Price drop
Old 06-18-2025, 02:42 PM   #7
Vegas Black SS
Back in Black
Price drop
