Old 12-05-2024, 10:18 AM   #1
Crazych66
Crazych66's Avatar
Drives: '12 Camaro 2SS/RS Vert
Low Brake Fluid Warning
2012 Camaro SS with OEM Brembos.
Had my car dyno tuned before Thanksgiving and it started to show "Low Brake Fluid" warning on the DIC and the "Brake" light is on. The fluid in the reservoir is good and I flushed the system and put in Dot 4 brake fluid this year. There doesn't seem to be any loss in braking performance. I understand there is a fluid level sensor in the master cylinder reservoir that can be replaced, just haven't heard many of those going bad. Any other suggestions on what to look for?
2012 Camaro SS Convertible: 2SS, LS3, M6, Triple Black. Mods: LSA S/C, FIC 1000 injectors, ZL1 fuel pump, Solo Axleback, 1LE FE6 rear swaybar, CAGS delete, Vararam CAI, Heritage grill, Hotchkis springs, '15 FE4 struts/shocks, ZL1 side rockers, Velgen Classic5 wheels, Pedders radius rod bushings, ARH LTHs, gutted HFCs,...
Crazych66 is offline   Reply With Quote
Old 12-05-2024, 11:30 AM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Well, if the brakes are working properly and you don't see any leaks, you could disconnect the negative battery terminal for a bit to clear the lights. The last time I had mine on the dyno, when we were done and I drove away, all my dash lights came on, and my tuner said they would go out before I left his building, and they did. Just something to look at since your lights came on. If there is a problem, they will come back on after you hook the battery back up and drive it again.
Old 12-05-2024, 11:45 AM   #3
Crazych66
Crazych66's Avatar
Thanks, forgot to mention we tried that already and it didn't help. Though I may try again!
Old 12-05-2024, 05:44 PM   #4
Mouse330
Mouse330's Avatar
Drives: 2011 2SS, 2006 GMC Sierra
There's most likely a code C0267 set in the EBCM(Electronic brake control module). A quick thing to check is to disconnect the level sensor connector and install a 3 Amp fused jumper wire between the signal circuit terminal 1 and ground. The sensor connector is only two wires. See if the light goes out. You can buy fuse holders at any parts store. If the light goes out you have a bad level sensor, If not it could need a EBCM. There is a lot of other factors to but this is something you cold do yourself.
Mouse330 is offline   Reply With Quote
Old 12-06-2024, 12:06 PM   #5
Crazych66
Crazych66's Avatar
Great tips - thanks!
Old 12-06-2024, 12:55 PM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Old 12-06-2024, 12:56 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
That's some cool info there Mouse!!
