Old 01-28-2010, 08:03 AM   #1
55Designs
Drives: 2010
Factory Gas Cap is driving me crazy every time I refuel because it hang/hits paint
I am about to cut the stupid plastic cord on the gas cap because its so distorted i cant get the cap to stay on the little recess on the door. so everytime i refuel the guys let it hang and its starting to leave marks in my paint from the friction. If there is some magical method to this please let me know. stupid design if you ask me
Options I am thinking about is removing the cord so the cap can just be taken off completly and put on the side of the gas pump until filled or make some sort of a more flexible cord to attach to the cap so i can rest it.
Am I the only one with this complaint?
55Designs is offline   Reply With Quote
Old 01-28-2010, 08:05 AM   #2
esperman
You Can Call Me Jay
esperman's Avatar
Drives: 2010 1LT RJT Manual w/CAI & Solo
it annoys me too.
somewhere here there is a link to a cool gas cap holder that sticks to the lid. Thinking about getting one.
esperman is offline   Reply With Quote
Old 01-28-2010, 08:06 AM   #3
EMB135Driver
Jedi Master
EMB135Driver's Avatar
Drives: Boeing 757/767+2010 IBM 2SS
Just hang it over the door instead of on the mini hook.....problem solved.
EMB135Driver is offline   Reply With Quote
Old 01-28-2010, 08:11 AM   #4
68blk/yel396
68blk/yel396's Avatar
Drives: 2011 RJT 2SS/RS
Hey Guys,
I had the same problem for a long time until I finally noticed a small hook on the inside of the door cover that you can loop the 1/8" round plastic connector line for the cover. When hooked, the cap doesn't hit the car anywhere. Let me know that you have found what I am describing.
68blk/yel396 is offline   Reply With Quote
Old 01-28-2010, 08:14 AM   #5
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
Post #3 works. It's how I fill up. Just turn the gas cap around so the side you touch with your hand is resting against the outside face of the gas cap door. It's easy, it works, and it doesn't cost a thing...
Old 01-28-2010, 08:16 AM   #6
CamaroKen
CamaroKen's Avatar
Drives: 2010 SIM SS
Here is the link that ESPERMAN is talking about.
http://GasCapCaddy.com
CamaroKen is offline   Reply With Quote
Old 01-28-2010, 08:17 AM   #7
mscaggs
mscaggs's Avatar
Drives: 2010 Camaro 2SS
I just use a rag I keep in the trunk, easy fix
mscaggs is offline   Reply With Quote
Old 01-28-2010, 08:17 AM   #8
OuSoonersGirl
I need a V-1 BAD!
OuSoonersGirl's Avatar
Drives: 2010 Camaro SS
Originally Posted by esperman View Post
it annoys me too.
you got that link?
but wouldn't it scratch or chip the paint on the edge of the door eventually?
OuSoonersGirl is offline   Reply With Quote
Old 01-28-2010, 08:19 AM   #9
OuSoonersGirl
I need a V-1 BAD!
thanks
Old 01-28-2010, 08:47 AM   #10
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Take a thin cable tie and make a loop around the cord on the gas cap. Put the loop around the hook on the door. You could also use string, or twine.
Old 01-28-2010, 08:47 AM   #11
kentf
Drives: 2010 camaro Black/White Stripes SS
I have the same problem. I think it is becasuse the plastic cord is too short and is not flexible. I just hang it over with the outside of the cap on the filler door. It is a bug GM needs to address for the next build.
kentf is offline   Reply With Quote
Old 01-28-2010, 09:10 AM   #12
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
That little hook on the back of the gas door is useless. I just gently let my gas cap hang down. Yes it touches the paint but with some care there is no reason it should damage the paint.
Old 01-28-2010, 09:12 AM   #13
jtzako
Drives: 2010 IBM Camaro SS
It hangs on the little hook just fine for me.
jtzako is offline   Reply With Quote
Old 01-28-2010, 09:15 AM   #14
baumy2eagle
Baumy2eagle
baumy2eagle's Avatar
Drives: 2010 Camaro & 96 GMC Jimmy
Send a message via Yahoo to baumy2eagle
SIMPLE: get the gas pump in one hand, take off the gas cap with other hand. Hold on to the cap while puting the pump in the tank and then when ready to fuel up, just wrap the gas cap over the pump handle...when done, grab the cap, take out the pump, put cap on and then put pump away....woohoo
2000- 8/5/2009
3800- 9/02/09 2G1FC1EV5A9143182
4200- 9/09/09
Brian Dean Baumgartner
voice over artist for movie trailers
imaging and liners for music
KIXS 108 Morning Show
http://www.myspace.com/baumy2eagleproductions
http://www.kixs.com
baumy2eagle is offline   Reply With Quote
Washing/Detailing for Newbies MRK III Z28 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 123 02-05-2024 09:55 PM
Got my Zaino today lordfriday2 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 261 05-31-2014 10:00 PM
GM bulletin on Perceived Paint Mismatch on Door and Quarter Panel Paint Appearance Tran Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 53 07-17-2013 01:16 PM
GM bulletin on Perceived Paint Mismatch on Door and Quarter Panel Paint Appearance Tran 5th Gen Camaro SS LS LT General Discussions 114 04-16-2012 03:04 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 09:03 PM
