![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS Join Date: Oct 2009
Removing Front Bowtie Support?
i am ordering the SLP front badges and center landing pad. I see there are posts on how to remove the bowtie from the factory pad but how do i replace the whole pad from the grille?
2010 IOM SS/RS LS3, Hennessey HPE550 Polished Magnuson TVS2300 Supercharger. 3.4 Pulley. Kooks long tube headers / high flow cats. GHL Full exhaust. ZL1 Fuel Pump/ADM FPCM. MSW Bap. JRE ZL1 Race cam with new springs/pushrods/Trunion Upgrade. FIC 850cc injectors. ZR1 Map sensor. CAI Induction. JRE Tune.
![]() Drives: 2010 camaro Join Date: Jan 2010
Do you mean take the whole grille out of the bumper cover? If so you have to remove the whole entire cover to do this. The grille can't be removed and "left out" because it is the support for the cover when it is installed.
This link may help you: http://www.camaro5.com/forums/showth...=grille+remove |
there is a center portion of the grille that carries the bowtie and the replacement looks like it is separate from the grille itself...
I believe the replacement has a bit of black plastic that extends to fill the gap left when removing the larger bowtie emblem. Is that what you are referring to?
Mods: BBK Intake, BBK LT's and High Flow Cats, Corsa Cat-back exhaust, Hurst short throw shifter, SLP skip-shift eliminator. 7/1/09 Placed order for IOM/IO int/ SS/RS 6M 9/26/09 Took delivery! |
Psssssssssshhhhhhhhhhhhh!
Drives: under contruction Join Date: Nov 2009
There is a part that replaces that grill piece. I've seen it mentioned. I'll see if I can find it.
Found it: http://www.slponline.com/view_product.asp?P=100032A Is that what you're looking for? Last edited by Darth_Emma; 01-28-2010 at 05:03 PM. |
#6 |
the picture above is what comes with the new badges.....apparently, the bowtie is removed and there is a piece behind the factory bowtie that looks similar to the one in the pic......I just need to know how to take out the factory backing plate to replace it with the one pictured above.
#7 |
![]() ![]() Drives: 10'2SS/RS,94'toyoda,02'vette Join Date: Dec 2009
i just put mine on yesterday from slp
not hard to install new ss just put ss on landing pad it has adheasive on the back and it fits right in place from where the old emblem was on |
#8 |
when the chrome bowtie comes off, is there a black piece behind it that comes out with it or is it separate from it and then itis removed and replaced with the new landing pad?
#9 |
2G1FB1EV7A9100028
Drives: 2010 Jeep Wrangler Hemi Join Date: Mar 2009
Okay the emblem comes out and there's a space where the SLP plastic piece goes in. There's two clips one on either side of the emblem and one in the middle they're like tabs you have to push to get it out. Once you get the emblem off you'll get what I'm saying. It was kind of a pain to do though to be honest.
# 28 - Victory Red 1LT/RS (SOLD)
#10 |
Drives: SuperCharged 2SS/RS IOM MN6 Join Date: May 2009
Take a look at your front bowtie and look and feel behind it and you will see how it is mounted on and the tabs/clips you have to push/pry off and the whole thing comes off.
#11 |
thanks so much for everybody's info! After reading all of this and finding this picture.....i finally got it through my brain that the factory bowtie doesnt have a landing pad......its is the landing pad. I feel like a complete idiot now but at lease this idiot has his answer......Thanks again! Kudos to my Camaro5 Family!
#12 |
and don't forget to post pics after you get the new one on.
#13 |
Will do
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
What about taking the factory SS emblem out. I thought I heard that one was a lot more difficult.
Build Journal ![]() |
| Attn: Fbodfather- Will GM save the Pontiac G8 for the U.S. market via rebadge? | TT C6 | General Automotive + Other Cars Discussion | 165 | 11-30-2010 08:43 PM |
| 2010 Camaro SS Blue in Syracuse NY $32690 | Mitsubishi in Syracuse | Camaro Price | Ordering | Tracking | Dealers Discussions | 0 | 12-31-2009 03:44 PM |
| No confirmation number? | jamesc1123 | Camaro Price | Ordering | Tracking | Dealers Discussions | 12 | 02-21-2009 09:49 PM |
| Front Comparison | digitalshow | 5th Gen Camaro SS LS LT General Discussions | 31 | 09-20-2008 09:06 AM |
