Old 12-09-2024, 02:24 AM   #1
jesse121pm
jesse121pm's Avatar
Drives: 2012 Camaro 2ss 45th anniversary
Truetrac Upgrade
I am trying to change the rear end on my 2012 Camaro ss manual. I have a DSS 1 piece aluminum driveshaft and my differential is starting to make noises from launches. What I am wondering is what is everything I need to build the rear end in the car and replace it with a truetrac. summit racing would be most convenient.
jesse121pm is offline   Reply With Quote
Old 12-09-2024, 04:40 AM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
The guys at Summit would likely gladly tell you that, but basically the TruTrac carrier, a new ring gear kit in the ratio of your choice and I would recommend a master kit as well with all new bearings and seals. Of course, one quart of gear oil.
Old 12-09-2024, 08:51 AM   #3
Bee
Bee's Avatar
Drives: SS/RS - Rally Yellow
I'm also preparing for a gear swap. I just received my TruTrac yesterday, but everything CamaroCracka mentioned is on my list as well.
The only other thing I'm planning to get, which is completely optional, is an LPW cover.
Check out my build here.
SEPA5 South Eastern Pennsylvania 5th Gen Camaro Club
Bee is offline   Reply With Quote
Old 12-09-2024, 02:25 PM   #4
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
I had mine set up @ a local shop & it is going in soon. AAM 3.91's with a master kit.
Bee, I was lucky to find a LPW cover on ebay awhile back. They are getting hard to find. I also heard that the Speedmaster covers have issues so if you consider one do some research.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
acutron42 is offline   Reply With Quote
Old 12-09-2024, 07:00 PM   #5
Bee
Bee's Avatar
Oh no...that's not what I want to hear, but thanks for the heads up. I guess I will have to start my search more sooner than later.
Good luck with your 3.91's!!
Old 12-15-2024, 11:12 AM   #6
11REDSS
Drives: 2011 Camaro ss
I have had a LPW cover on order for almost 10 months now, so be prepared to wait.
2011 Camaro 2SS Victory Red
Rotofab CAI, 160 Thermostat, Stainless Works Headers, Livernois Motorsports Thunderstorm Exhaust, GPI SS1, rodmod intake, ported tb by GPI, Remote
Tune by GPI, Elite Engineering Catch Can, Rotofab washer relocation, JRE scoop, JRE Trans dipstick, BMR Toe Rods, BMR Trailing Arms, BMR subframe connectors, Polyurethane diff bushing and rear cradle mount's, RSM front crash bar
11REDSS is offline   Reply With Quote
Old 12-15-2024, 11:52 AM   #7
Turbobitt
Drives: 2010 2SS
I did the Eaton true track install and used there install kit P/N K-GM8.6-10IRS. The kit had all the seals except the cover but did have Timken bearings.
AG.
Turbobitt is offline   Reply With Quote
Old 12-15-2024, 07:52 PM   #8
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Also maybe look to source a Z28 diff same as a TruTrac but they might a little spendy now days.
Orange Krush II
differential
