Old 01-28-2010, 09:11 PM   #1
3BVert
3BVert's Avatar
Drives: 2010 Camaro 2SS/RS
Heated Seat Issue
We have a weird issue with the heated seat on the passenger side. When it’s cold out (< 40 degrees), the heater won’t stay on (at first). It lights up for about a second and then turns off. After the interior temperature warms up, it will stay on. When it’s warmer outside, it works right off the bat.
At first I figured it was a short or a bad connection under the seat but jiggling the wiring under there doesn't have any effect. The problem went away when the weather warmed up last week. It wasn't until it got colder today that I thought that the temperature might have something to do with it.
It’s not quite bothersome enough for me to take it in for service just yet. Any ideas?
2SS/RS Red Jewel Tintcoat
6-Speed Automatic
3BVert is offline   Reply With Quote
Old 01-28-2010, 10:00 PM   #2
Number 3
Hail to the King baby!
Number 3's Avatar
Easiest thing to check is any connections under the seat. Make sure they are solidly connected.
Old 01-28-2010, 10:18 PM   #3
vuduman67
Drives: Victory Red 2SS/RS
My drivers seat does the same thing, I took it to the dealer and of course it worked every time. Very annoying. I figure it will probably quit altogether soon. Just have to wait and see I guess.:(
vuduman67 is offline   Reply With Quote
Old 09-27-2010, 11:57 PM   #4
MartiMcFly
MartiMcFly's Avatar
Drives: 2SS-RS
I just started having an issue with my passenger side. I push the button and it comes on for about a second or two seconds and turns right off. At times it will stay on for a few minutes and than turn right off.
MartiMcFly is offline   Reply With Quote
Old 09-28-2010, 12:03 AM   #5
MartiMcFly
MartiMcFly's Avatar
Drives: 2SS-RS
The drivers side stays on and turns off when I turn it off.
Also the passenger seat won't respond to turning it to heat level 1 when it is on.
baby/car seat question kellertxgen5 5th Gen Camaro SS LS LT General Discussions 41 10-26-2014 05:55 PM
Electrical / Transmission / Wire Harness Issue - Issue Solved RichD 5th Gen Camaro SS LS LT General Discussions 6 02-16-2014 09:54 PM
Killer Driver Seat The Stig Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 7 06-28-2010 12:04 PM
new member and a question on child booster seat MEPoPo 5th Gen Camaro SS LS LT General Discussions 12 08-24-2009 02:10 PM
Please Think before you post 35th02ss Off-topic Discussions 35 08-02-2009 10:38 AM
