Old 12-24-2024, 12:01 AM   #1
econ
Drives: 2013 2ss
Relocating the mass airflow sensor....Why?
Just got this kit...
econ is offline   Reply With Quote
Old 12-24-2024, 08:37 AM   #2
cdb95z28
cdb95z28's Avatar
Drives: 2022 1SS 1LE A10 BCD WCT+PDR
Return it, you're asking for trouble. GM spends alot of time calibrating based on the mass airflow sensor in the OE location. Any deviation can introduce changes in airflow that was not accounted for in the cal.
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
"KEEP THE FAITH"-Fbodfather
cdb95z28 is offline   Reply With Quote
Old 12-24-2024, 10:27 AM   #3
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Wrong “kit” or wrong application?
0stones0 is offline   Reply With Quote
Old 12-24-2024, 01:55 PM   #4
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
That is 2011-14 kit with oem air box.
Old 12-24-2024, 02:41 PM   #5
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
I just have to wonder why start another thread on the same subject?
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
acutron42 is offline   Reply With Quote
Old 12-26-2024, 12:04 PM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Agreed... The answers aren't going to be any different..
Old 12-28-2024, 12:27 PM   #7
econ
Drives: 2013 2ss
Allow me to explain. I started this thread and it did not show up. After quite a while it still did not show up. So I added to a preexisting thread and that post did show up right away. Then after a while, this thread showed up, finally. I had no intention of asking the same thing twice.
Old 01-04-2025, 04:22 AM   #8
DarylKidd
Drives: Swift 2015
Have you got your answer?
DarylKidd is offline   Reply With Quote
