![]() Drives: 2012 SS Join Date: Feb 2016
Manual trans oil
Did a search & couldn't find anything. What is the best atf to use in our manual cars. I'm thinking Redline d4. Good choice? Thanks in advance!
2012 2SS/RS 6speed, Howards asa cam on 113lsa Stainless works LT's, NPP exhaust, Z28 Cai, 3.91 gears. Tuned by Blue Thunder 2 racing Lubbock Texas.
"Cam Only"
Yes, Redline D4 is the way to go.
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger, Monster S Series Triple Disc Clutch | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles | Mickey Thompson ET Street R 305/45/18 |
Tuned by Ryne @ CMS E85: 734rwhp/674rwtq |
![]() Drives: 2010 Chevy Camaro 2SS coupe (MT) Join Date: Jan 2024
I rant a lot about all the potential transmission fluids and gear oils you can actually appropriately run in a Tremec TR-6060, but any standard viscosity spec ATF will work. If it’s a generic “multi vehicle” ATF spec, it’s most likely just some form of Dexron III/Mercon ATF. I highly suggest going full synthetic if possible, however. ATF+4 is a standard viscosity spec ATF that comes naturally fully synthetic by it’s manufacturing process; highly recommended if looking for a budget friendly alternative.
Other high performance or high mileage duty ATF’s for TES 295, 398, and 668 are typically the top-of-the-line SV (standard viscosity) spec ATF’s that are made for heavy duty automatic transmissions like Allison, ZF, etc. for semi-trucks, etc. They’re all fully synthetic and have a superb additive package (ex: Amsoil Torque Drive, Valvoline Syngard ES, Mobil Delvac 1). I believe Castrol makes their version called Transynd 668; however, it was more leaning towards LV (low viscosity) spec ATF and was more or less a Dexron LV/Mercon LV ATF (too thin for hard driving conditions). Aside from that, you can maybe even seek some full synthetic Mercon V ATF, although they’re generally even less common than finding full synth Dex III ATF in my experience. If you in a US state with O’Reilly, they carry their own line of full synthetic Mercon V ATF, although I believe it only comes in individual single quarts only. For what it’s worth, I got a gallon (~3.78 qt/L technically) of O’Reilly ATF+4 ATF for around $36 out the door. You definitely can’t beat that (minus purchasing an extra quart of ATF to top off). Nothing wrong with conventional ATF; I just prefer full synthetic for their additive packages (as claimed; some tested), as it seems to hold up a lot longer and better than conventional ATF choices. If you’re a person like me who changes ATF like once a year or every other year, you can still most certainly tell the difference as cheaper, conventional begins to shear and break down in it’s weight, viscosity, etc. Obviously if I lived in a super hot climate area, I’d probably run a choice of some kind of GL-4 75w-80 (Synchromesh MTF, Redline MTL) or 75w-85 (ex: Tremec HP MTF, Redline MT-85) gear oil full time. Hell, I even ran Honda OEM MTF at one point, which is somewhat of a GL-4 70w-75 supposedly. It wasn’t that bad, and I’ve also ranted about DCTF’s (dual clutch ATF) at some point, since those are also naturally fully synthetic by production, and are typically around the same weight and viscosity as standard viscosity ATF’s I mentioned above. If you wanna do your own research, you can check out Bobistheoilguy’s forum, and there’s plenty of topics and threads on there about what you can and/or should run in your transmission (specific or not). Also, it looks like you have a 2012 SS (from your side bio), which should mean that you have the revised factory hybrid synchronizers. I’m sure you probably won’t have to worry about my rant unless you’re a person who bangs gears all the time or tracks their car super often. |
It don’t come easy.
Redline is what I went with. No issues.
Pricing fluctuates so often for Redline products, but the inflation in the past 6-7 years or so has pretty much led me to trying other brands and similar spec trans fluids/oils. However, I’m thinking my pre-2012+ synchronizers play a role, and it won’t matter what fluid I run, since it always feels notchy 70% of the time.
I’ve made sure my clutch hydraulics are bled and don’t have any air whatsoever. Once in a while, if I do a trans fluid change (once a year or year and a half) and find that my shifting is still notchy, I check the clutch pedal and bleed it again, just to be safe. Unfortunately, I’ve come down to the conclusion that it’s either my Hurst billet short shifter or the older 2010-2011 TR-6060 synchronizers. I find myself kinda paranoid about the clutch hydraulics and the quality of shifting, since I recently went through 2-3 CMC’s in the span of roughly 2 years or so. I even replaced the factory clutch line for a stainless steel braided one, which seem to also help quite a bit as well. The clutch pedal engagement point is still kinda vague, but that’s probably a different topic… I’m merely waiting for the factory clutch slave cylinder to die eventually, as it’s one of those ticking time bomb wear parts. Most of my trans fluid changes have a fair amount of metallic sparkles or debris that I genuinely think, is the synchronizers or whatever yellow metals wearing away… I double check my drain pan and make sure it’s spotless before I drain the trans. At this point, I’m considering doing a trans fluid/oil analysis. I’ll post it on Bobistheoilguy and then probably share the results on here too. |
