Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Members Area > Ask the Camaro Team
Old 01-21-2025, 09:47 PM   #1
CamarOklahoma
Drives: Lt1
Manifold connector replacement? Where to buy ?
I own a 2019 Camaro lt1 rs
Had a family member replace my thermostat, upon removing the manifold cover he broke the white clip on the black connector. He then zip tied it and left it alone, I'm not upset cause I know it can be fixed.
My issue is, I have no idea what the connector is called or for. I will attach a video screenshot of the area. It's too cold for me to go and get a picture
Can someone please help me ?
CamarOklahoma is offline   Reply With Quote
Old 01-22-2025, 11:33 AM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I believe you should be alright. The white clip is usually just the "locking" portion of the connector that holds it in place. As long as the connector is fully seated, it should be alright. I broke mine on my MAF connector looonnngggg time ago, and it's been fine.
Old 03-01-2025, 09:39 AM   #3
Simshahh
Drives: Zl1
I have a basically unlimited supply of those connectors. I can send you one and either a) you splice in the whole connector or b) you pull out the broken cpa and put a new one in its place. Either way, if the connecor is locked in, the cpa just makes sure it doesnt go anywhere, but that style connector doesnt need a cpa, they are a tricky one to remove by itself.
Simshahh is offline   Reply With Quote
