Old 01-22-2025, 02:28 PM   #1
MR.Sarge
MR.Sarge's Avatar
Drives: 2015 2SS/RS CRT 1LE
Magnuson TVS2650 Tower Brace spacers?
Looking to install a Magnuson TVS2650 this spring when the car is out of hibernation, and was wondering if anyone installed one that had a 2014-2015 with the strut tower brace?
I know it doesn't fit it but I am wondering if the brace can still be used with spacers, or is there no room at all and just have to take the L and go without the brace?
Pics would be great, and if spacers work, what size spacers are you running?
MR.Sarge is offline   Reply With Quote
Old 01-22-2025, 04:18 PM   #2
1911 1LE
Drives: 2015 SW 2SS 1LE
I reinstalled mine after was told it wouldn't work. Had to do some grinding to clear the hood strut bracket and elongate the mounting holes till the bolts would line up. I used flat washers as shims to get to the clearance I wanted and then machined aluminum spacers for final assembly. Be careful not to go too high. My bolts just barely touch the underside of the hood when closed. PM me your phone number and I'll send you some pics.
Maggie 2650 @ 18psi/ 75mm 10 rib/ Dual alky nozzles/ Roto-fab/ ARH 2" Lt's/ GT-12 cam/ ZL1 3.23 Conv./MGW/RPS triple carbon clutch/RSG tranny upgrage/Pedders Ex. XA w/ remote cans and a lot of other crap 897/8??@tires
1911 1LE is offline   Reply With Quote
Old 01-22-2025, 06:39 PM   #3
MR.Sarge
MR.Sarge's Avatar
Thanks! PM sent!
Old 03-09-2025, 12:17 AM   #4
Dega Man
Drives: ZL1
Are you going with the 2650 pi or the 2650 hot rod?
Dega Man is offline   Reply With Quote
