![]() Drives: 2013 ZL1 Join Date: Nov 2018
Oil cooler seals part number needed
Search gave me the middle finger.
I searched them online at GM and the picture of it shows a green o ring, then it shows where it's located and it shows the adapter to block gasket. Is this the correct part number GM (12613165)? Oil cooler is leaking, I need the 4 green o rings that go here.
2015 1SS 1LE, Magnuson 2300 Heartbeat and headers. 550rwhp STD, 535 SAE.
![]() Drives: 2011 Camaro 2SS/RS Join Date: Jul 2021
https://www.camaro5.com/forums/showthread.php?t=69736
The PDF in this thread has most all part numbers. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Many have deleted the cooler because of them leaking.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
![]() Drives: 2013 ZL1 Join Date: Sep 2021
You can go to a good parts store and get Nitril o-rings-. Make sure they are nitrile not Buena N. Also make sure the mounting surface is perfectly flat.
Tri-County Camaro SWFL
Yes that's the correct part number. Amazon has them at 9 dollars a gasket. That's my next fun adventure because mine started leaking as well.
#6 |
After looking a little closer, mine was oil cooler to block gasket leaking.
#7 |
It don’t come easy.
It’s been said that these mating surfaces were never good from the getgo. That’s why you’ll find quite a few deletes occurring.
#8 |
Stayed sealed up for 130,000 miles, it's been good.
#9 |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
Whats the down side of deleting the oil cooler and how effective is it?
#10 |
Optimum oil temperature is 230°-260°
#11 |
Turns out it was not the block to cooler seal, I will buy the o rings and see if I can save it.
Question to the ones who know, I watched a video on how to pull the cooler on a LS3 and it did not have any coolant running through the cooler. It appears the ZL1 has coolant lines going to it?
#12 | |
From my understanding, it acts as both an oil warmer and an oil cooler. The factory cooler uses the coolant to cool the oil. The coolant tends to heat up faster from a cold start then the oil which helps get the oil warmed. When the engine is heated up, the coolant temp is kept cooler then the oil, hence "cooling" the oil. Like many here have pointed out, it is a system that is not very effective and prone to failure. Many, including myself, have deleted it because of that.
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Custom Mishimoto Oil Cooler, BMR Tunnel Brace, Custom Dual Mishimoto Oil Catch Cans, MSD Plug Wires, Mishimoto Radiator and Hoses, Melling High Volume/High Flow Oil Pump, Improved Racing Oil Pan Baffle Kit, Improved Racing Oil Pressure Bypass Delete, Improved Racing Oil Pick-up Tube Clamp. |
#13 | |
![]() Drives: 2010 Chevy Camaro 2SS coupe (MT) Join Date: Jan 2024
I got sick of it still leaking, so I took the cooling block/heat exchanger assembly apart, drained it for like half a day, alternating angles to get all the leftover oil and coolant out. Then, I basically cleaned the rest of the mating areas as much as possible and applied Permatex 90-minute black, high temp, oil resistant RTV gasket maker onto the entire face of the cooling block. I didn’t really have a “method” per say; it was more like alternating lines and such to make sure there was essentially no way for any leaks to occur in between any of the makeshift “borders”. I’ll upload a rough photo of what I did, if I can still find it… It pretty much ended up curing, although it seeped/weeped a teeny tiny bit for like a few hours until I drove back from work and left it until the following morning. It ended up working for the entire next year and a half, while I was prepping parts to set up my custom air-to-oil engine oil cooler setup, to get rid of the stock engine oil cooler. I would’ve also left it alone after rigging it to stop leaking honestly, but I felt like it leaking was a massive PITA, and you also couldn’t further improve the engine/oil cooling. People apparently ran the Mishimoto oil cooler kit with the factory oil cooler still intact, but I didn’t like the sandwich plate oil filter feed adapters, as well as the efficiency of both of the coolers running together. Needless to say though, I went with a 200F degree thermostatic Improved Racing oil pan feed with -10 AN threaded adapters, which I ran to a 25-row oil cooler. It’s pretty much identical to the Mishimoto kit, as I got their parts list as a starting point and then sourced my own individual parts, for their quality and to my “needs”. Works fine and my estimated engine oil temps are anywhere around 215-225 in like a sub-90F degree ambient temp conditions, with NORMAL driving. I might find a way to get better transmission fluid and engine oil temp readings, and my thermostatic oil feed actually has a blocked off port I can run an oil temp sensor to. |
