Old 01-30-2025, 04:23 AM   #1
Marko76
Drives: 2015 Camaro 2SS 1LE
1LE info?
Hey guys, apologies if this has been beat to death, but the search function isn't working at the moment. Every time I try to use it, it shut down. I'm recently in the market for a 2SS 1LE. If the 5th digit of the VIN is a J doesn't that automatically make it a 1LE? I've seen several sales on line that do not list the 1LE package, but have a J 5th digit. I'm just trying to make sure I'm not jumping the gun, Tia
Marko76 is offline   Reply With Quote
Old 01-30-2025, 07:47 AM   #2
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
As far as I know, you have to check the RPO tag in the trunk to confirm it came with the 1LE package. I'm sure someone else will chime in if there's another way.
Sent from my Pixel 8 Pro using Tapatalk
Old 01-30-2025, 09:54 AM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
This ^^ The "J" designates that the car has the 6.2L L99 engine in it.. Some info for ya.
https://www.camaro5.com/forums/showthread.php?t=419477
Old 01-30-2025, 10:56 AM   #4
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
You guys are correct. The vin doesn't designate 1LE because it's just a package, not any sort of trim level. The RPO sticker and a white steering shaft is the only true way to confirm a 1LE.
https://www.camaro5.com/forums/showthread.php?t=212140
There are a few 1LEs in the for sale section here,
Old 01-30-2025, 11:41 AM   #5
larry_g
larry_g's Avatar
If a "J" designates the L99 then it can't be a 1LE, weren't they all LS3?
Old 01-30-2025, 12:40 PM   #6
cdb95z28
cdb95z28's Avatar
Drives: 2022 1SS 1LE A10 BCD WCT+PDR
All Gen5 SS 1LE's are LS3 with the TR6060 transmission. There were no automatic Gen5 SS 1LE's. While the VIN doesn't necessarily call out 1LE, the Service Parts ID tag will call out the RPO 1LE code, along with the suspension code, FE6.
BTW, yeah the search here on the forums sucks. Just go to google, and type your search and add "camaro5.com". You'll find threads from the forums you need.
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
"KEEP THE FAITH"-Fbodfather
cdb95z28 is offline   Reply With Quote
Old 01-30-2025, 12:44 PM   #7
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Well there's your answer...
Old 01-30-2025, 06:10 PM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yes, you are correct.
Old 01-30-2025, 10:06 PM   #9
NiteProwlerSS
Matt
NiteProwlerSS's Avatar
Drives: 2012 Camaro SS
The engine code is the 8th digit of the VIN, op mentioned the 5th digit. Since the 1le is an option for SS models and not an actual model I doubt it can be decoded from the vin.
2012 Camaro 2SS LS3 M6
NiteProwlerSS is offline   Reply With Quote
Old 01-31-2025, 04:44 AM   #10
King Nothing
Turning wrenches
King Nothing's Avatar
Drives: 2011 Camaro SS By Berger 11BC21
Am I the only one thinking the OP is either a bot or a spammer just from his sentence structure?
Sold-2006 Pontiac GTO
M6 1 of 475
353rwhp 353rwtq
Sold-2000 Camaro SS A4 Hardtop #867 of 8913
1 of 103 Bright Rally Red Hardtop SS A4 in 2000
1 of 25 and only SIM Camaro By Berger in 2011 year, 2011 Camaro 2SS/RS M6 By Berger #11BC21
King Nothing is offline   Reply With Quote
Old 01-31-2025, 05:46 AM   #11
Marko76
Not a bot or a spammer. Just a regular dude with poor sentence structure, and an interest in the gen5
Old 01-31-2025, 09:08 AM   #12
Marko76
So how do I get a car lot across the country to send me a pick of the RPO without them figuring out they might have a drastically under priced car on their lot? LOL
Old 01-31-2025, 09:23 AM   #13
cdb95z28
cdb95z28's Avatar
Send me the VIN, either here on this thread or if you prefer, thru a PM. I'll look up the RPO codes.
Old 02-01-2025, 10:09 AM   #14
Level300
Drives: 2015 Black rs/ss/1le
In the trunk is the build sheet, driver side under the carpet. Ask for a picture of this to get undeniable proof.
A 2014/15 1le should have the following:
White steering shaft (although ive read that some didn’t have this, most do, mine does) (quickly narrows your search)
3.73 rear gears
Tr6060 tranny
Ls3 motor
Alacantra shift knob and steering wheel (quickly narrows your search)
Matte black hood (but someone could easily remove or add this) (quickly narrows your search)
The cool looking 10 spoke zl1 wheels, rs option (quickly narrows your search)
Popular OPTIONS: dual mode exhaust, recaro seats, 2ss
Good luck in your search. Don’t forget to track it at least once if you get one!
Level300 is offline   Reply With Quote
