Old 02-04-2025, 11:45 AM   #1
Lacpac
Lacpac's Avatar
Drives: 2012 Crystal Red Tintcoat RS
2012 Rear Bulbs convert to LED
Does anyone know the bulb size for the rear tail light / brake light for the 2012 model? I get conflicting info. I'd like to buy a canbus LED replacement for the incandescent bulbs. I've done this on other cars I own and am pleased with the results vs. buying $400 LED Tailight assemblies. I guess I could always pull the current bulb... in storage now. Thanks
Lacpac is offline   Reply With Quote
Old 02-04-2025, 08:14 PM   #2
spyderbuddy
Check with sealight-led they had mine for a 2010
Old 02-05-2025, 10:28 AM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I saved this link in my favorites because a forum member installed them in his Camaro with no issues he said.
https://www.amazon.com/gp/product/B0...ie=UTF8&psc=1v
Old 02-06-2025, 03:36 PM   #4
Trawz
Trawz's Avatar
Drives: 2013 Camaro 1LE
I converted nearly all lights on my 2013 1LE to LED from VLEDs back in 2019
They are based in Bellingham Washington and I have yet to have any bulb failure.
These are the ones I am running in the tail lights:
https://www.vleds.com/shop-applicati...it-r-3157.html
They are VERY bright and get people's attention.
They will require a small resister to not throw a turn signal warning on the dash, but the resister just plugs into the bulb. No need to splice in any wires. Very easy install.
2013 1SS/1LE
Corsa Extreme cat-back, Speed Engineering LT Headers with black ceramic coating, C7 Z06 Front Brake Upgrade, Custom Mishimoto Oil Cooler, BMR Tunnel Brace, Custom Dual Mishimoto Oil Catch Cans, MSD Plug Wires, Mishimoto Radiator and Hoses, Melling High Volume/High Flow Oil Pump, Improved Racing Oil Pan Baffle Kit, Improved Racing Oil Pressure Bypass Delete, Improved Racing Oil Pick-up Tube Clamp.
Trawz is offline   Reply With Quote
Old 02-10-2025, 01:19 PM   #5
Lacpac
Lacpac's Avatar
Thank you, I'll check this out.
Old 02-11-2025, 05:04 PM   #6
SS_Dave
SS_Dave's Avatar
Drives: 2011 Camaro 2SS/RS
Man. Do they send someone to install them? Those suckers are spendy for LED's.
SS_Dave is offline   Reply With Quote
Old 02-12-2025, 08:25 AM   #7
SL33P3R
SL33P3R's Avatar
Drives: 2013 Camaro SS Vert
https://www.diodedynamics.com/tail-l...maro-four.html
Best LED bulbs out there. I have the XP80s with full black taillight covers and they are as bright if not brighter than the stock bulbs with no covers.
SL33P3R is offline   Reply With Quote
Old 02-12-2025, 03:20 PM   #8
Trawz
Trawz's Avatar
Yes, they are on the expensive side, but they are among the brightest in the market (800+ lumens) and very high quality.
Oracle Lighting is more expensive for what you get.
2013 1SS/1LE
Old 03-03-2025, 01:20 PM   #9
Lacpac
Lacpac's Avatar
https://www.camaro5.com/forums/album...ctureid=172322
Went with these for Front turn signals, they work great and are bright. $36 on amazon.
Old 03-04-2025, 01:40 AM   #10
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
I have these.I have had to replace one resistor..
Old 03-04-2025, 09:10 AM   #11
SS_Dave
SS_Dave's Avatar
First time I've ever seen a taillight bulb with a cooling fan in it.
Old 03-28-2025, 09:40 PM   #12
ghost_l2yder
Drives: 2013 camaro zl1
Gen5concepts makes modified oem sockets that you can run any led bulb in them without getting a fast flash error. Plug n play.
ghost_l2yder is offline   Reply With Quote
