What's an LSA engine worth?
Thinking about selling my current engine complete to help pay for something else, but really don't know what it's worth.
What do you guys think this could get? Currently configured...700whp on E85 30,000 miles on engine Cam done at 11,000 miles 2014 LSA with stock bottom end and stock heads. BTR stage 3 cam BTR .660 springs spring kit and titanium retainers with BTR valve seals. BTR 5/16 chromoly pushrods BTR v2 Rocker trunnion upgrade kit Kong Performance porting on supercharger and snout Metco solid isolator Billet lid coolant manifold Griptek upper pulley 2.50" w/hub ATI Super Damper DSX Tuning 9.06 Lower pulley 3 bolt cam gear with ARP bolts Katech C5R Timing chain Dedicated Motorsports Idler Relocation Bracket Dedicated Motorsports 110mm Idler LS2 chain damper ARP balancer bolt HD Greenback belt K080675HD F.I.Clinic 1200cc Injectors NW 102mm throttle body Aeroflow fuel rails 169 deg. Mishimoto Thermostat oil pickup tube girdle NGK 3690 spark plugs gapped .033 Melling 10355HV oil pump DOD/AFM relief valve Delete in the LSA oil pan McLeod RXT1200 clutch I'll probably keep the oil pan. Thanks for the input. Mark Last edited by FasNuf; 02-05-2025 at 01:12 PM. |
![]() Drives: 2013 ZL1 Join Date: Sep 2021
On Ebay they run about $12,000-$16,000 for a stock LSA engine, most with more miles than yours. Usually performance additions take a huge hit when someone is buying a car but on an engine sale alone that doesn't hold true so you won't take a bath. I would think it would sell at $15,000-$16,000 in a reasonable amount of time.
Keep me in mind if you want to sell the clutch separate. |
#3 | |
Thanks guys.
Looking at a Dart 427 but I'm not firm on the details yet. Most likely going 2650 for the boost. I'm really in the early stages of figuring it out. Just trying to see what kind of money I'm looking at for a budget. |
![]() ![]() ![]() Drives: 2013 zl1 vert Join Date: Dec 2018
Damn Mark you’re finally doing it. I know we talked about it last summer. Big time plans.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
#6 | |
#7 |
For some reason I'm not getting notified when people reply so sorry in advance.
Yes, hopefully soon I'll be gathering parts. I may just get a Thompson short block to save time. Hoping they put it up soon as engine of the month.
